Tranz main shaft guide bolt, Looks like JB weld |
malcolm2 |
Apr 18 2019, 02:19 PM
ClayPerrine |
Apr 18 2019, 03:30 PM
Life's been good to me so far..... Group: Admin Posts: 15,463 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Any of the listed inserts above will work.
But I would recommend that you measure the depth of the hole, and when you drill it out for the insert, wrap some tape around your drill bit as a stop. It is really easy to drill all the way through and end up with a gear oil leak. |
bdstone914 |
Apr 19 2019, 09:01 AM
bdstone914 Group: Members Posts: 4,520 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Any of the listed inserts above will work. But I would recommend that you measure the depth of the hole, and when you drill it out for the insert, wrap some tape around your drill bit as a stop. It is really easy to drill all the way through and end up with a gear oil leak. (IMG:style_emoticons/default/agree.gif) Also remember the exact height of the ball pivot is important. If the flywheel is machined to the max the ball pivot stud needs to be shimmed out to get the correct throw out arm geometry. I would attempt to measure the installed height. I hav a trans case and can measure that for you if needed. Bruce |
malcolm2 |
Apr 19 2019, 10:55 AM
Any of the listed inserts above will work. But I would recommend that you measure the depth of the hole, and when you drill it out for the insert, wrap some tape around your drill bit as a stop. It is really easy to drill all the way through and end up with a gear oil leak. (IMG:style_emoticons/default/agree.gif) Also remember the exact height of the ball pivot is important. If the flywheel is machined to the max the ball pivot stud needs to be shimmed out to get the correct throw out arm geometry. I would attempt to measure the installed height. I hav a trans case and can measure that for you if needed. Bruce Since my plan is to keep the current FW, i would like to know about the geometry. So you wouldn’t measure thickness of the flywheel as well? Please do Bruce, Thanks |
Lo-Fi Version | Time is now: 15th May 2024 - 12:52 PM |
