Fuel Tank fittings & pads |
Gatornapper |
Apr 19 2019, 09:21 AM
Senior Member Group: Members Posts: 1,215 Joined: 22-September 17 From: Woods west of Richmond, VA Member No.: 21,449 Region Association: South East States |
When I got my 914 the tank was not in the car. I had the tank restored, but the guy lost the fittings that connect to the bottom of the tank. The fittings are no longer available anywhere.
Can anyone tell me the size of the fittings? They seem to be about 14mm dia., fine metric thread. Also, I cannot tell where the rubber pads go that support the tank on the seam - I was told they go on the sides, but I cannot tell where. See my post #53 under "Newbie from virginia..." Can someone attach a pic of where they go or describe their placement precisely? I'm dead in the water getting the car running without these fittings and knowing the placement of the pads. Thanks for the help! GN |
dr914@autoatlanta.com |
Apr 19 2019, 09:36 AM
914 Guru Group: Members Posts: 7,853 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
wow sorry you lost them, the pads go in three places, vw used pieces for the factory carpet to make then, we can send you a pic. The nipples must be sourced used as they cannot be easily made. WE have the strainer sock, both large and small nuts and the two crush washers new
When I got my 914 the tank was not in the car. I had the tank restored, but the guy lost the fittings that connect to the bottom of the tank. The fittings are no longer available anywhere. Can anyone tell me the size of the fittings? They seem to be about 14mm dia., fine metric thread. Also, I cannot tell where the rubber pads go that support the tank on the seam - I was told they go on the sides, but I cannot tell where. See my post #53 under "Newbie from virginia..." Can someone attach a pic of where they go or describe their placement precisely? I'm dead in the water getting the car running without these fittings and knowing the placement of the pads. Thanks for the help! GN |
Gatornapper |
Apr 19 2019, 10:58 AM
Dr914 -
Not long after I posted this, I figured out where the black rubber pads go, on either lower side of the tank on the rim. The 'carpet' pieces are in place and no problem. I have a new strainer sock, ready to go in if I can find the nuts - both are the same size, about 17mm. I think I can make the nipples in my shop if I have the 2 nuts and crush washers. So glad you have the nuts! But would I be able to locally source them as a standard metric part? Will call..... GN wow sorry you lost them, the pads go in three places, vw used pieces for the factory carpet to make then, we can send you a pic. The nipples must be sourced used as they cannot be easily made. WE have the strainer sock, both large and small nuts and the two crush washers new When I got my 914 the tank was not in the car. I had the tank restored, but the guy lost the fittings that connect to the bottom of the tank. The fittings are no longer available anywhere. Can anyone tell me the size of the fittings? They seem to be about 14mm dia., fine metric thread. Also, I cannot tell where the rubber pads go that support the tank on the seam - I was told they go on the sides, but I cannot tell where. See my post #53 under "Newbie from virginia..." Can someone attach a pic of where they go or describe their placement precisely? I'm dead in the water getting the car running without these fittings and knowing the placement of the pads. Thanks for the help! GN |
Lo-Fi Version | Time is now: 14th May 2024 - 04:16 AM |
