Fuel Tank fittings & pads |
Gatornapper |
Apr 19 2019, 09:21 AM
Senior Member Group: Members Posts: 1,215 Joined: 22-September 17 From: Woods west of Richmond, VA Member No.: 21,449 Region Association: South East States |
When I got my 914 the tank was not in the car. I had the tank restored, but the guy lost the fittings that connect to the bottom of the tank. The fittings are no longer available anywhere.
Can anyone tell me the size of the fittings? They seem to be about 14mm dia., fine metric thread. Also, I cannot tell where the rubber pads go that support the tank on the seam - I was told they go on the sides, but I cannot tell where. See my post #53 under "Newbie from virginia..." Can someone attach a pic of where they go or describe their placement precisely? I'm dead in the water getting the car running without these fittings and knowing the placement of the pads. Thanks for the help! GN |
jcd914 |
Apr 24 2019, 08:11 AM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
For the fuel system ”jerry-rig something" isn't a good choice.
Put a WTB ad in the classified section here and someone will offer up the tubes/nipples you need. There are some regulars that sell used parts here that probably have them. I believe there are two different size outlet tubes, early cars use a larger outlet tube at the tank. The change came when they moved the fuel pump up front under the fuel tank. There are several here running carbs and keeping the return line so the fuel recirculates and stays cooler. Jim |
Lo-Fi Version | Time is now: 14th May 2024 - 03:14 PM |
