Door Cam Replacement, Drill The Rivet? |
Nogoodwithusernames |
Apr 19 2019, 09:45 AM
Member Group: Members Posts: 237 Joined: 31-May 16 From: Nor-Cal Member No.: 20,051 Region Association: None |
Hey guys, time to fix one of my door handles. The plastic cam broke. I'll probably pull the passenger side and clean the inner mechanism and replace the cam on that side too just to be safe.
I've got the driver side all cleaned and lubed up in the door, but cannot figure out how to get the plastic cam off to replace it. The handle doesn't open enough to let it slide out so do I need to drill the rivet and replace it with a shoulder bolt or something? PS I did try to read through some of the other threads about door handles but haven't found anything specifically regarding this yet. |
Mikey914 |
Apr 19 2019, 01:53 PM
The rubber man Group: Members Posts: 12,669 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Mine don't snap. Made these specifically to address that defect You change the formal on the nylon to make it harder, but they do act as a fuse to prevent excessive load on the handle, Lubricate the mechanism on the door as well as the lock. It often is more a matter of all the other parts moving freely. Shouldn't take much pressure with your finger to pop the lock. You will see when you have the door handle off.
Lo-Fi Version | Time is now: 17th May 2024 - 07:51 PM |
