Door Cam Replacement, Drill The Rivet? |
URY914 |
Apr 22 2019, 07:02 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,318 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
DO NOT break the "legs" off the flapper part of the handle. There are no quality replacements for this piece. I can fix the broken mounting tab.
Mikey914 |
Apr 23 2019, 10:22 AM
The rubber man Group: Members Posts: 12,649 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I think he meant the legs on the plastic cam.
GeorgeKopf |
Oct 26 2021, 08:38 PM
Member Group: Members Posts: 172 Joined: 9-February 21 From: Princeton, NJ Member No.: 25,186 Region Association: MidAtlantic Region |
I would like to get the plastic flapper/lever thingy off of my door handles without breaking them. Does that mean that I have to remove the pin holding everything together?
Thanks. George |
Mikey914 |
Oct 26 2021, 10:38 PM
The screw and end piece, yes.
Solocholo |
Nov 23 2021, 08:43 AM
Newbie Group: Members Posts: 7 Joined: 20-July 21 From: California Member No.: 25,739 Region Association: Southern California |
I know I made mine with a notch so that you can extend the flap (pull the handle), and the notch will allow you to rotate the cam on and into place. Once installed it doesn't have this range of motion so it stays in place. Does this help? Sweet I will knotch mine and try the trick too Attached image(s) |
Luke M |
Nov 23 2021, 10:12 AM
Senior Member Group: Members Posts: 1,370 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
I just rebuilt my brothers door handles using the 914rubber kits. It was super easy to install the new cam. Took less then 2 mins to cut the old cam out and get the new one on. Took longer to clean and polish the door handles. (IMG:style_emoticons/default/first.gif) for the 914rubber parts.
Lo-Fi Version | Time is now: 3rd May 2024 - 12:23 AM |
