WTB turn signal swithc assembly, Mine won't self cancil |
barefoot |
Apr 22 2019, 10:28 AM
Senior Member Group: Members Posts: 1,270 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
Mine is 76, but all yrs seem to be the same for this assy.
Got one but had open circuit couldn't fix Barefoot |
914Sixer |
Apr 22 2019, 01:26 PM
914 Guru Group: Members Posts: 8,872 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
All the turn signals switches are the same now, only the wipers are different for 75-76. Your clips are probably broken. Tricky trying to put the used ones back in with out damaging something else. Probably easier to replace with new one. Pictures added, no spare parts. Might be able to cheap switch and use parts from it.
Attached image(s) |
tmessenger |
Apr 22 2019, 04:24 PM
Member Group: Members Posts: 70 Joined: 6-December 18 From: Iowa Member No.: 22,707 Region Association: Upper MidWest |
I have a used one I'll take a look at it.
tmessenger |
Apr 26 2019, 08:54 AM
Here are some photos of what I have note the wear points on the copper contacts for the horn (1st photo).
$35 + shipping. Tim |
barefoot |
Apr 27 2019, 06:28 AM
PM sent to buy
Barefot |
barefoot |
May 1 2019, 07:12 PM
Bump, need switch assy.
Chi-town |
May 1 2019, 07:22 PM
Senior Member Group: Members Posts: 850 Joined: 31-August 18 From: Disneyland Member No.: 22,446 Region Association: Southern California |
These are available new from Pelican
Mblizzard |
May 2 2019, 07:13 AM
Advanced Member Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
Did you check to make sure the tab on the 901 613 325 05 cancelling ring was making contact? These wear or break off sometimes.
mepstein |
May 2 2019, 07:15 AM
914-6 GT in waiting Group: Members Posts: 19,254 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Bump, need switch assy. I have a couple used ones I’ll send you for the cost of shipping. PM me your address if you want them. @barefoot |
barefoot |
May 2 2019, 11:00 AM
Did you check to make sure the tab on the 901 613 325 05 cancelling ring was making contact? These wear or break off sometimes. No my tab is fine mine was missing the "W"spring and one little locating tab is broken off, so new switch assy is needed Thanks for info |
barefoot |
May 25 2019, 08:18 AM
Bump, still need turn signal switch assembly, mine shot.
Barefoot |
Lo-Fi Version | Time is now: 3rd May 2024 - 05:54 AM |
