Used Compu-Fire or Used Pertronix?, Which used ignition module should I use? |
jcd914 |
Apr 24 2019, 05:02 PM
I have 3 used pointless ignition modules that came with one of my parts cars or project.
First 2 are Compu-Fire units, one loose in a box of other stuff and one in the distributor on an engine. 3rd is a Pertronix unit that was loose in a box of other stuff. I don't actually know if any of them work but the engine that one of them is in was supposedly running on mega-squire before it was pulled from the car. I am looking to put one of these into my 2.0l D-jet engine which is running solid core copper plug wires. I have no recent experience with pointless ignition in a 914 but there are no points in my engine now and I need something and I have these. Thoughts? Thanks Jim |
worn |
Apr 24 2019, 05:42 PM
can't remember Group: Members Posts: 3,156 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
I have 3 used pointless ignition modules that came with one of my parts cars or project. First 2 are Compu-Fire units, one loose in a box of other stuff and one in the distributor on an engine. 3rd is a Pertronix unit that was loose in a box of other stuff. I don't actually know if any of them work but the engine that one of them is in was supposedly running on mega-squire before it was pulled from the car. I am looking to put one of these into my 2.0l D-jet engine which is running solid core copper plug wires. I have no recent experience with pointless ignition in a 914 but there are no points in my engine now and I need something and I have these. Thoughts? Thanks Jim I suppose it will come down to personal preference along with how many of the three actually work. I have a pertronix unit in my TR6 and trust it, but that is a considerably cooler environment hanging on the side of a water cooled block than sitting on top of air and oil cooled 914. I think that I killed one by reverse polarity, so watch out for that. |
IronHillRestorations |
Apr 25 2019, 07:11 AM
I'm not a fan of Pertronix, I wish I had better luck with them. I think the idea is great, but I recently lost money putting a whole new Pnix ignition system in a customer's 914 and the ignitor went bad in less than 500 miles
jonferns |
Apr 25 2019, 07:28 AM
Still running the same Pertronix unit that was installed in the late 90’s, without issue. Not sure if the newer units are any less reliable.
rfinegan |
Apr 25 2019, 07:53 AM
Senior Member Group: Members Posts: 973 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region |
Compufire is big on air cooled Harleys
I have on one my 1.8 75 914 and no problems |
Bleyseng |
Apr 25 2019, 08:20 AM
I am putting in a new pertronix today as I had a old guy moment and wired the old one backwards killing it. (IMG:style_emoticons/default/mad.gif)
Johny Blackstain |
Apr 25 2019, 08:40 AM
Walnut Elite Stratocaster player Group: Members Posts: 3,434 Joined: 5-December 06 From: The Shenandoah River Member No.: 7,318 Region Association: MidAtlantic Region |
I use the Pertronix in my LE however I replaced the coil, also with Pertronix, to match the module voltage-wise. Been fine for 12 years now. (IMG:style_emoticons/default/cool_shades.gif)
Spoke |
Apr 25 2019, 08:41 AM
I've used Pertronix in 2 different 914's without issue.
krazykonrad |
Senior Member Group: Members Posts: 1,126 Joined: 21-February 06 From: Canton, GA Member No.: 5,610 |
Are Compu-fire and Pertronix compatible with the D-Jet contacts on the distributor?
Spoke |
Apr 25 2019, 08:42 AM
Johny Blackstain |
Apr 25 2019, 08:43 AM
dr914@autoatlanta.com |
Apr 25 2019, 03:50 PM
914 Guru Group: Members Posts: 7,864 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
comp u fire seems to handle the heat better on the air cooled engines than pertronix, but is a bit harder to fit
Mark Henry |
Apr 26 2019, 05:44 AM
I have a compufire on a 009. I tried on my T1 in my '67 bus, couldn't get rid of a miss.
Ended up yanking it and now use a mallory with a pertronix. I don't know if it was a 009 or compufire issue, I still have it kicking around, but haven't looked at it in 15 years. |
914werke |
Apr 26 2019, 03:43 PM
"I got blisters on me fingers" Group: Members Posts: 10,066 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
BTW Compufire owns the Pertronix brand ...or vica versa
jcd914 |
Apr 26 2019, 03:59 PM
Thanks for all the information all.
I actually chose not to use either right now and put a set of points back in it. The engine has not been run for several years. @ConeDodger Rob, how long ago did you give me the engine back? I just rewired a lot of the car, re-plumbed the fuel system and installed the engine. I figured that having one less unknown electronic unit in the mix would be smart. If it does not start I won't be wondering if it is a bad ignition module. After I address any FI or wiring issues and get it running I can swap in one of the units. Thanks Jim |
ConeDodger |
Apr 26 2019, 04:08 PM
Apex killer! Group: Members Posts: 23,588 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Jim I think three years or more? I left it at Original Customs for you to pick up...
jcd914 |
Apr 26 2019, 05:18 PM
Lo-Fi Version | Time is now: 17th May 2024 - 06:32 PM |
