FS: 914-6/RS 380mm Steering Wheel |
juche_namja |
Apr 25 2019, 04:20 PM
I'm new here ... Group: Members Posts: 0 Joined: 18-June 18 From: Arizona Member No.: 22,234 Region Association: None |
Originally purchased for my 67S, but with two other wheels to use this one will not make the cut. Beautifully restored 914-6 RS leather wrapped 380mm steering wheel PN 914 341 805 11, date code 10/71, restored spokes, raised hub and and cross-drilled for use of 911/912. Never mounted or used. $1250 + shipping & fees. chal_saeng_gin@hotmail.com
mb911 |
Apr 25 2019, 07:33 PM
914 Guru Group: Members Posts: 6,851 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Ok no expert here but shouldn't the last 2 digits be 10 for an RS wheel? |
Apr 25 2019, 08:01 PM
Ok no expert here but shouldn't the last 2 digits be 10 for an RS wheel? It’s a 914 hub, not a 911 hub. So it works, just not perfectly. The chamfer where the hub sits on the steering shaft is different between 911 and 914 hubs. By drilling and taping two small holes in the back, the cancel ring can be fitted and splines are the same but it doesn’t fit properly to the shaft. Good may be good enough and many are sold and used this way but .... |
Chi-town |
Apr 26 2019, 08:16 AM
Senior Member Group: Members Posts: 850 Joined: 31-August 18 From: Disneyland Member No.: 22,446 Region Association: Southern California |
Corrected by mepstein
Will Fit 1972 914-6 with VW column |
juche_namja |
Apr 26 2019, 08:35 AM
Apr 26 2019, 08:49 AM
ST/R/RS/RSR & 914 STEERING WHEELS 914 347 803 10: 70/71 914-4 plastic base for original ST/R/RS/RSR 914 347 804 10: early 4s, flat hub/sunk hub 914 347 804 11: late 4s, sunk hub/flat back – plastic rim 914 347 805 10: early 4s & 6s, leather, flat hub/recessed back (best) 914 347 805 11: ’72 914-4 w/ 90 degree sunk hub/flat back 86mm grip 914-4 914 347 806 10: Leather -6 Original RS wheel w/ 72mm grip 914 347 806 11: 91mm grip 914 347 088 10: very early VW/Porsche leather wheel 914 347 809 00: ‘74 914s, sunk hub/ faux leather 901 347 081 10: extremely rare 400mm thick grip leather all cross-stitch http://www.early911sregistry.org/forums/sh...heels-THE-TRUTH That chart is not correct. The 803 10 wheel was a six only wheel. Never used on a 4. The 805 10 was an early four wheel. Never used on a six. The early S guys compile the charts based off of what sellers list in their ads, not what is really true. I’ve never seen or heard of an 806 11 but it could be from a ‘72 914-6 since it used a vw column. I’ll take some pics of the different steering shafts but I can assure you the Porsche and VW shafts differ and the Porsche factory never used a VW style hub on a Porsche column. Just making the 911 turn signal cancel ring fit on a vw style hub doesn’t mean the wheel fits the car. |
Chi-town |
Apr 26 2019, 08:59 AM
@mepstein The stepped splines on the rear designate a VW column correct?
1972 914-6 came with a VW column, correct? His screen shot of the parts catalog would designate the 914 347 805 11 as both for 914-4 and 914-6 but it would that make it incorrect RS wheel. |
Apr 26 2019, 09:38 AM
@mepstein The stepped splines on the rear designate a VW column correct? Yes 1972 914-6 came with a VW column, correct? Yes His screen shot of the parts catalog would designate the 914 347 805 11 as both for 914-4 and 914-6 but it would that make it incorrect RS wheel. Yes, depending on dates. Dates are very important for the guys that care about accuracy. I don’t (IMG:style_emoticons/default/biggrin.gif) There are a lot of RS “style” wheels built from all different models and years. There are a couple people with RS cars with real wheels. The ‘72 914-6 was a short run production. I’m pretty sure they used 805 11 but that doesn’t really make an 805 11 a “universal” 914-6 wheel, just one for that year. |
SixerJ |
Apr 26 2019, 02:44 PM
Member Group: Members Posts: 448 Joined: 24-June 13 From: UK Member No.: 16,042 Region Association: England |
Chi-town |
Apr 26 2019, 05:41 PM
Apr 26 2019, 06:17 PM
My narrow grip RS wheel for visual reference. Fairly sure the 70 and 71 -6 wheel is physically the same, bar the date stamp GLWTS See there's no step in the rear of the splines, that's what makes it a 911 or 70-71 914 wheel And flat on the front and the horn cancel ring is recessed into back of the wheel, unlike a mid year/late 914 wheel. |
mountainroads |
Apr 26 2019, 10:06 PM
Member Group: Members Posts: 210 Joined: 19-February 12 From: Seattle Member No.: 14,145 Region Association: Pacific Northwest |
My narrow grip RS wheel for visual reference. Fairly sure the 70 and 71 -6 wheel is physically the same, bar the date stamp GLWTS See there's no step in the rear of the splines, that's what makes it a 911 or 70-71 914 wheel OK, I'll step into this. Is that "1 73" on the back of the hub in the middle pic a date code? If so.... - MR |
juche_namja |
Apr 28 2019, 07:58 AM
Price drop $1100.
juche_namja |
May 1 2019, 04:04 PM
Price drop. $1050.
juche_namja |
May 4 2019, 08:38 AM
Price drop $1000.
juche_namja |
May 9 2019, 06:58 AM
Price drop $975.
Lo-Fi Version | Time is now: 17th May 2024 - 06:42 PM |
