6 Oil Tank Restoration |
tailwind22 |
Apr 27 2019, 09:57 AM
Member Group: Members Posts: 88 Joined: 7-November 17 From: Moses Lake, WA Member No.: 21,583 Region Association: Pacific Northwest |
I have an original 914-6 oil tank that needs a good internal clean and flush and has had some rough silver solder patch work done. Can anyone recommend a good source to restore the tank to acceptable condition? I can then weigh the cost of restoration versus the cost of one of the after market varieties.
toolguy |
Apr 27 2019, 11:35 AM
Senior Member Group: Members Posts: 1,268 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
I had mine hot tanked at a radiator shop. . bet they could fix it also
jmalone |
Apr 27 2019, 12:10 PM
Member Group: Members Posts: 119 Joined: 3-July 09 From: reno,NV Member No.: 10,529 Region Association: Northern California |
I have an original 914-6 oil tank that needs a good internal clean and flush and has had some rough silver solder patch work done. Can anyone recommend a good source to restore the tank to acceptable condition? I can then weigh the cost of restoration versus the cost of one of the after market varieties. These were originally copper plated to prevent corrosion. I have a 911 tank that is rusted because of the failure of the copper coating. I haven't attempted to repair it. I wonder if a chrome plating shop could re-copper the tank. Has anyone attempted this? |
tailwind22 |
Apr 27 2019, 01:16 PM
I had mine hot tanked at a radiator shop. . bet they could fix it also I don't have a good radiator shop in town that I would trust. I do believe that a radiator shop that has done collector restorations would be a good bet. I was looking for a reference to send the tank out to. |
Apr 27 2019, 01:28 PM
I used aircraft stripper on the outside then lightly bead basted the corroded parts while leaving as much of the copper as possible. Then I ultrasonically cleaned it and applied semi gloss powder coat.
The real tanks are better made than the reproductions so i would make every effort to restore the original. Pacific coast oil cooler can do the repairs for you or just a good local shop. It's nothing that special. |
tailwind22 |
Apr 27 2019, 05:36 PM
I used aircraft stripper on the outside then lightly bead basted the corroded parts while leaving as much of the copper as possible. Then I ultrasonically cleaned it and applied semi gloss powder coat. The real tanks are better made than the reproductions so i would make every effort to restore the original. Pacific coast oil cooler can do the repairs for you or just a good local shop. It's nothing that special. Thanks Mike |
Lo-Fi Version | Time is now: 17th May 2024 - 07:51 PM |
