914 Six Gt hood pin plates, Looking for square original GT not the round one s |
Dr916Gt |
May 1 2019, 02:37 PM
Newbie Group: Members Posts: 4 Joined: 10-April 19 From: Murrieta California Member No.: 23,029 Region Association: Central California |
(IMG:style_emoticons/default/beerchug.gif) if anyone knows where I could pick up a set or two of the 914 Six Gt hood pin plates please let me know as soon as possible. Thanks very much
mb911 |
May 2 2019, 07:28 AM
914 Guru Group: Members Posts: 6,854 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Here are correct dimensions but not showing the angles and chamfers
ConeDodger |
May 2 2019, 08:32 AM
Apex killer! Group: Members Posts: 23,592 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
They aren’t square.
Jeff is the source. And, he’ll make them out of stainless or aluminum or... I Have the drawings somewhere, but easier just to PM sixnotfour (IMG:style_emoticons/default/evilgrin.gif) Attached image(s) |
mb911 |
May 2 2019, 09:39 AM
@coneDodger look at my pictures they are not square this is dimensions from an NOS set from a friends stash 90 minutes to south of me.. (IMG:style_emoticons/default/biggrin.gif)
mlindner |
May 3 2019, 04:29 AM
Senior Member Group: Members Posts: 1,522 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
sixnotfour |
May 3 2019, 04:31 AM
914 Wizard Group: Members Posts: 10,432 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Ben his are not square,,,I know your friend.... when mounted they look square because of the 914s crazy lines,,,
i mean beautiful Attached image(s) |
mb911 |
May 3 2019, 05:03 AM
(IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/biggrin.gif). I never said they were square (IMG:style_emoticons/default/poke.gif)
jfort |
May 3 2019, 07:29 AM
Senior Member Group: Members Posts: 1,135 Joined: 5-May 03 From: Findlay, OH Member No.: 652 Region Association: Upper MidWest |
I believe this is the right link but no photo so I'd ask them - https://www.mittelmotor.de/cms/en/914-6-zub...8846-neu-detail 914-6 GT parts main page https://www.mittelmotor.de/cms/en/914-6-zub...-914-6-gt-teile 914-6 GT body sub page https://www.mittelmotor.de/cms/en/914-6-zub...eile/5418/0-088 Thanks for the links! I think this is what I am looking for but there is no picture HOOD LOCKING 914/6 GT FRONT, COMPLETE SET TEILENUMMER 914.511.904.71 Agree? |
ConeDodger |
May 3 2019, 07:41 AM
(IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/biggrin.gif). I never said they were square (IMG:style_emoticons/default/poke.gif) No one is talking about you Ben. A previous post said words to the effect, ‘they’re square, how hard is that.’ And then edited it away. |
sixnotfour |
May 3 2019, 08:33 AM
I believe this is the right link but no photo so I'd ask them - https://www.mittelmotor.de/cms/en/914-6-zub...8846-neu-detail 914-6 GT parts main page https://www.mittelmotor.de/cms/en/914-6-zub...-914-6-gt-teile 914-6 GT body sub page https://www.mittelmotor.de/cms/en/914-6-zub...eile/5418/0-088 Thanks for the links! I think this is what I am looking for but there is no picture HOOD LOCKING 914/6 GT FRONT, COMPLETE SET TEILENUMMER 914.511.904.71 Agree? @campbellcj Attached image(s) |
mb911 |
May 3 2019, 08:37 AM
(IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/biggrin.gif). I never said they were square (IMG:style_emoticons/default/poke.gif) No one is talking about you Ben. A previous post said words to the effect, ‘they’re square, how hard is that.’ And then edited it away. Sorry that was tongue in cheek . (IMG:style_emoticons/default/biggrin.gif) |
Mikey914 |
May 3 2019, 11:57 AM
The rubber man Group: Members Posts: 12,670 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Perhaps I should start with making the pins. Then guys that do their own thing can buy separate from the kit. As far as doing the lip we can do that, but how many sets should I end up making?
sixnotfour |
May 3 2019, 01:59 PM
campbellcj |
May 3 2019, 07:12 PM
I have not seen much addressing the mounting of the pins to the car. The kit I got did not account for attachment of the frontmost pins, so there was some minor fab entailed. Another minor annoyance is I've found the nuts come loose; should switch to nyloc nuts but it's hard enough as it is getting/holding the pin height and orientation right while tightening the fasteners. My car vibrates and runs at high speed/rpm much more than the typical 914, tho.
mlindner |
May 4 2019, 04:33 AM
campbellcj |
May 4 2019, 02:22 PM
Yup that's exactly what I did
Literati914 |
May 4 2019, 03:02 PM
Senior Member Group: Members Posts: 1,461 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
mlindner |
May 4 2019, 06:04 PM
Mine is just aluminum stock reveted under hood seal. Mark Mark, what are those nylon leveling pieces you used? Just nylon spacers from the local hardware store. Drilled center to match latch pins and belt sanded the nylon to correct angle, both top and bottom. Nice part about it, as you rotate the pin... you can match the above hood pin hole perfectly. This is not an issue with fiberglass hoods (flex), but mine is the original steel and wanted to have it line up correctly with a round hole in the hood. Hope that helps. Best, Mark |
mlindner |
May 4 2019, 06:11 PM
Just FYI...Pin angle should be 71 degrees (90 degrees is vertical) for correct angle from base of pin. This make hood/pin alignment very easy. Mark
Lo-Fi Version | Time is now: 19th May 2024 - 01:41 PM |
