FS: Front suspension/brakes upgrade. |
914Toy |
May 5 2019, 01:25 PM
Senior Member Group: Members Posts: 718 Joined: 12-November 17 From: Laguna beach Member No.: 21,596 Region Association: Southern California |
FS: Upgrade your front suspension with later model 914 Bogey struts (wedge bolt), with Bilstein inserts, rotors drilled for and with 5 lugs pressed in, along with BMW 320i calipers with good brake pads. Just removed from my car to install 911 SC struts, hubs, rotors and calipers. All of these items (see pic) are in excellent condition - bearings, inserts, calipers and pads only have about 3,000 miles on them, and this package includes all the bolts, nuts, washers and short hard brake lines for installation
$400 plus shipping from S. Cal - can pack in a plastic carton for shipping. SOLD. |
914Toy |
May 8 2019, 08:38 AM
FS: Upgrade your front suspension with later model 914 Bogey struts (wedge bolt), with Bilstein inserts, rotors drilled for and with 5 lugs pressed in, along with BMW 320i calipers with good brake pads. Just removed from my car to install 911 SC struts, hubs, rotors and calipers. All of these items (see pic) are in excellent condition - bearings, inserts, calipers and pads only have about 3,000 miles on them, and this package includes all the bolts, nuts, washers and short hard brake lines for installation $400 plus shipping from S. Cal - can pack in a plastic carton for shipping. New price $400 plus shipping. |
betz |
May 8 2019, 10:29 AM
Member Group: Members Posts: 76 Joined: 22-October 18 From: San Leandro, CA Member No.: 22,593 Region Association: Northern California |
Can I run these on an early model? Also I'm guessing I can just run stock 4 lug by using my own hubs & rotors?
Tdskip |
May 8 2019, 11:37 AM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Believe so but get a 2nd opinion.
Seller is a good guy BTW. |
914Toy |
May 8 2019, 01:05 PM
Can I run these on an early model? Also I'm guessing I can just run stock 4 lug by using my own hubs & rotors? The early type strut had a "squeeze" bolt to secure the ball joint to the bottom of the strut. The later models have a wedge bolt which is more secure - preferred. Thus you will like these struts. The rotor/hub is one piece and is the 914 type, just drilled with 5 studs pressed in. Thus your stock rotors/hubs will fit these struts. the BMW brake calipers are considered an upgrade and will work with the stock 17 mm or the larger 19 mm master cylinder. I have 19 mm master cylinder. So short answer, yes (IMG:style_emoticons/default/beerchug.gif) |
914Toy |
May 8 2019, 07:51 PM
Can I run these on an early model? Also I'm guessing I can just run stock 4 lug by using my own hubs & rotors? The early type strut had a "squeeze" bolt to secure the ball joint to the bottom of the strut. The later models have a wedge bolt which is more secure - preferred. Thus you will like these struts. The rotor/hub is one piece and is the 914 type, just drilled with 5 studs pressed in. Thus your stock rotors/hubs will fit these struts. the BMW brake calipers are considered an upgrade and will work with the stock 17 mm or the larger 19 mm master cylinder. I have 19 mm master cylinder. So short answer, yes (IMG:style_emoticons/default/beerchug.gif) I now have a commitment from a local fellow to purchase this complete lot this Saturday. Will repost of deal falls through. |
betz |
May 9 2019, 02:44 PM
Can I run these on an early model? Also I'm guessing I can just run stock 4 lug by using my own hubs & rotors? The early type strut had a "squeeze" bolt to secure the ball joint to the bottom of the strut. The later models have a wedge bolt which is more secure - preferred. Thus you will like these struts. The rotor/hub is one piece and is the 914 type, just drilled with 5 studs pressed in. Thus your stock rotors/hubs will fit these struts. the BMW brake calipers are considered an upgrade and will work with the stock 17 mm or the larger 19 mm master cylinder. I have 19 mm master cylinder. So short answer, yes (IMG:style_emoticons/default/beerchug.gif) I now have a commitment from a local fellow to purchase this complete lot this Saturday. Will repost of deal falls through. Let me know. I will be in So cal the weekend of the 25th but otherwise It would be shipping to Nor Cal. I'm interested either way, though. |
914Toy |
May 9 2019, 03:27 PM
Can I run these on an early model? Also I'm guessing I can just run stock 4 lug by using my own hubs & rotors? The early type strut had a "squeeze" bolt to secure the ball joint to the bottom of the strut. The later models have a wedge bolt which is more secure - preferred. Thus you will like these struts. The rotor/hub is one piece and is the 914 type, just drilled with 5 studs pressed in. Thus your stock rotors/hubs will fit these struts. the BMW brake calipers are considered an upgrade and will work with the stock 17 mm or the larger 19 mm master cylinder. I have 19 mm master cylinder. So short answer, yes (IMG:style_emoticons/default/beerchug.gif) I now have a commitment from a local fellow to purchase this complete lot this Saturday. Will repost of deal falls through. Let me know. I will be in So cal the weekend of the 25th but otherwise It would be shipping to Nor Cal. I'm interested either way, though. Will do. |
KevinP |
May 17 2019, 02:52 PM
Member Group: Members Posts: 205 Joined: 16-November 04 From: Orlando,FL Member No.: 3,127 |
if the deal falls, let me know. I'll take em.
914Toy |
May 17 2019, 09:19 PM
These are Sold.
Lo-Fi Version | Time is now: 17th May 2024 - 05:02 PM |
