1.7 Timing Help, Vacuum Hoses |
tvdinnerbythepool |
May 10 2019, 05:58 PM
Member Group: Members Posts: 310 Joined: 24-July 18 From: Olympia, WA Member No.: 22,336 Region Association: Pacific Northwest |
Hey all,
I'm timing my 1.7l Djet. I pulled the vacuum hoses off the distributor canister. Do I block the hoses or do I block the 2 vacuum ports on the distributor? Or both? Thanks! -Rob |
mark04usa |
May 10 2019, 06:50 PM
'70 1.7 Tangerine Group: Members Posts: 351 Joined: 14-September 09 From: Austin TX Member No.: 10,805 Region Association: Southwest Region |
Just plug the vacuum hoses with golf tees or similar...not the dist. vac/retard ports. Set dwell first at 44-50 deg, then set timing at the 27btdc mark at 3500 RPM if it is a stock setup. (IMG:style_emoticons/default/beerchug.gif)
tvdinnerbythepool |
May 10 2019, 08:46 PM
Just plug the vacuum hoses with golf tees or similar...not the dist. vac/retard ports. Set dwell first at 44-50 deg, then set timing at the 27btdc mark at 3500 RPM if it is a stock setup. (IMG:style_emoticons/default/beerchug.gif) Thank you!! |
May 10 2019, 08:50 PM
It's not actually necessary to do that on a D-jet car, but it's a good habit to get into because it is absolutely critical to do in some other cars.
--DD |
mark04usa |
May 10 2019, 10:28 PM
It's not actually necessary to do that on a D-jet car, but it's a good habit to get into because it is absolutely critical to do in some other cars. --DD Actually, the procedure I noted is by the book. As I understand, disabling the vac. advance by pulling the vac line is necessary so that only centrifugal advance is in play while setting timing. (IMG:style_emoticons/default/driving.gif) |
May 11 2019, 10:20 PM
Oops. I meant plugging the lines. That part isn't necessary but is good practice. Disconnecting them is necessary.
Sorry for not being clear. --DD |
Lo-Fi Version | Time is now: 19th May 2024 - 02:31 AM |
