2 Pages V < 1 2
> Hood Catch Problems, Pulling the handle won't release the catch.
defianty
post May 14 2019, 01:33 AM
Post #21
QUOTE(Mikey914 @ May 14 2019, 04:25 AM) *
The tie down is important I see that others have mentioned.
We use the same materials factory did only ours are 40 years + newer so yes they seem more flexable. It works well as long as routes correctly and tabs are holding it down. Check the routing through the headlight bucket area.
Once route is confirmed, check the action of the latch installed in place. Make sure the clamp ant the latch is holding the cable sheath securely. Without latching the hood you should be able to pull on the end of the cable to minimize slack at the latch. Push the latch to the closed position. When the cable is pulled the latch should release without the hood closed easily.
You fan use a helper to see exactly what the issue is. This is how I determined I had not routed the cable correctly under the light bucket.
I suspect you may have the same issue here.
It's a pretty simple system but the little details will compromise the ability for it to work correctly. I was surprised it was this finicky, but yes it makes a difference.
Mark
Thanks for your input Mark. I've not had a look at this again yet. I felt a bit burnt out from the car yesterday so decided to take a break for a couple of days. I think I've got plenty of info from the group to troubleshoot this now.
Mikey914
post May 14 2019, 02:20 PM
Post #22
The rubber man
Good plan. No need to beat yourself. Sometimes things are more clear when you can take a step back and regroup.
2 Pages V < 1 2
- Lo-Fi Version Time is now: 31st July 2025 - 02:07 PM
