Rebuilt calipers, Help needed |
Fatarse |
May 14 2019, 01:56 PM
Newbie Group: Members Posts: 12 Joined: 25-June 16 From: Scottsdale, AZ Member No.: 20,143 Region Association: None |
Right rear brake looks to have locked up after a recent caliper rebuild (less than 50 miles). I followed a pelican article and loosened the hex by going clockwise...wouldn’t twist counter. Brake pads look like they are glued to the rotor though...if anyone is in Phoenix area, there’s a six pack for anyone wanting to come to the garage and help me get the car on the road.
Attached thumbnail(s) |
Chi-town |
May 14 2019, 10:27 PM
Simply pull the little pin out at the connection from the cable to the caliper.
If the cable is stuck the caliper will release when the pin is pulled |
Fatarse |
May 16 2019, 06:29 PM
This sounds incredibly simple, but any pictures or diagrams of what pin I’m supposed to pull?
mepstein |
May 16 2019, 07:10 PM
914-6 GT in waiting Group: Members Posts: 19,295 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
This sounds incredibly simple, but any pictures or diagrams of what pin I’m supposed to pull? The pin that connects the end of the ebrale cable to the ebrake lever arm on the caliper. It has a tiny c-clip on the end. On the east coast they are always corroded over so I get them cherry red with map gas and then work it loose. |
Fatarse |
May 18 2019, 01:28 PM
Trying to take the pads out. Tried using a screwdriver, but not wiggling at all. Any suggestions?
Fatarse |
May 18 2019, 04:20 PM
Got one pad out, but no luck on the inner. Rotor still won’t rotate...any thoughts?
Fatarse |
May 18 2019, 04:32 PM
After tapping the arm I was able to get the rotor to rotate and remove the inner brake pad. Everything looks clean.
Lo-Fi Version | Time is now: 28th May 2024 - 03:47 AM |
