911S strut assemblies, Inserts don't fit |
framos914 |
May 14 2019, 09:31 PM
Member Group: Members Posts: 125 Joined: 15-May 14 From: Corona California Member No.: 17,353 Region Association: Southern California |
Need help. My 75 2.0 has worn strut inserts, PO replaced front struts with what I believed were 1977 911S Koni struts part #911 341 079 16 stamped on it. Bought inserts Koni 86-1942. Problem is they bottom out before going in far enough to secure them with the round nut.
Could I have 72-74 911S struts? Did they have the same part number? And are those inserts (86-1638) just a little shorter to seat further down. The 1942s seem to be just about 12mm too long, body of the 1942 is 374mm long. Tried getting info from a few places including Koni but no luck. Thanks |
914Sixer |
May 15 2019, 06:02 AM
914 Guru Group: Members Posts: 8,882 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
I have a set of Koni 86-1942 and I have test fitted them in stock 73-on Boge Struts. You have to use the Boge nut but they fit. I have a set of 86-1647 which are made different but fit the same.
One on right is the 1942 and left one is 1647. BOTH are the same length. 14 1/2 inces or 37 cm. Attached image(s) |
Lo-Fi Version | Time is now: 18th May 2024 - 01:44 AM |
