911S strut assemblies, Inserts don't fit |
framos914 |
May 14 2019, 09:31 PM
Member Group: Members Posts: 125 Joined: 15-May 14 From: Corona California Member No.: 17,353 Region Association: Southern California |
Need help. My 75 2.0 has worn strut inserts, PO replaced front struts with what I believed were 1977 911S Koni struts part #911 341 079 16 stamped on it. Bought inserts Koni 86-1942. Problem is they bottom out before going in far enough to secure them with the round nut.
Could I have 72-74 911S struts? Did they have the same part number? And are those inserts (86-1638) just a little shorter to seat further down. The 1942s seem to be just about 12mm too long, body of the 1942 is 374mm long. Tried getting info from a few places including Koni but no luck. Thanks |
mepstein |
May 14 2019, 09:47 PM
914-6 GT in waiting Group: Members Posts: 19,254 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Off the top of my head, it sounds like you are trying to put inserts made for 3 1/2" struts into a 3" strut. The later strut bodies are taller than the earlier ones.
framos914 |
May 14 2019, 09:58 PM
Off the top of my head, it sounds like you are trying to put inserts made for 3 1/2" struts into a 3" strut. The later strut bodies are taller than the earlier ones. The struts are 3.5 inch, It also has the 911S aluminum calipers not the M calipers which I believe are the 3 inch.Even though the the receipt in the POs documents say 1977 suspension, it could be wrong. These components were installed on this car way back in 1980. |
Lo-Fi Version | Time is now: 4th May 2024 - 03:25 AM |
