911S strut assemblies, Inserts don't fit |
framos914 |
May 14 2019, 09:31 PM
Member Group: Members Posts: 125 Joined: 15-May 14 From: Corona California Member No.: 17,353 Region Association: Southern California |
Need help. My 75 2.0 has worn strut inserts, PO replaced front struts with what I believed were 1977 911S Koni struts part #911 341 079 16 stamped on it. Bought inserts Koni 86-1942. Problem is they bottom out before going in far enough to secure them with the round nut.
Could I have 72-74 911S struts? Did they have the same part number? And are those inserts (86-1638) just a little shorter to seat further down. The 1942s seem to be just about 12mm too long, body of the 1942 is 374mm long. Tried getting info from a few places including Koni but no luck. Thanks |
sixnotfour |
May 15 2019, 08:56 AM
914 Wizard Group: Members Posts: 10,419 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
real Koni Struts.. require a unique shock insert ...call paragon products Koni 86-1638
https://www.paragon-products.com/Koni-Strut...8-p/86-1638.htm |
framos914 |
May 15 2019, 03:38 PM
real Koni Struts.. require a unique shock insert ...call paragon products Koni 86-1638 https://www.paragon-products.com/Koni-Strut...8-p/86-1638.htm Thanks Spoke with Jason at Paragon, he is 100% sure there is something at the bottom of the strut keeping the insert from dropping all the way down. The mechanic disagrees so I'll follow Jason's advice, pick up the car and take it apart myself. |
Lo-Fi Version | Time is now: 4th May 2024 - 01:48 PM |
