911S strut assemblies, Inserts don't fit |
framos914 |
May 14 2019, 09:31 PM
Member Group: Members Posts: 125 Joined: 15-May 14 From: Corona California Member No.: 17,353 Region Association: Southern California |
Need help. My 75 2.0 has worn strut inserts, PO replaced front struts with what I believed were 1977 911S Koni struts part #911 341 079 16 stamped on it. Bought inserts Koni 86-1942. Problem is they bottom out before going in far enough to secure them with the round nut.
Could I have 72-74 911S struts? Did they have the same part number? And are those inserts (86-1638) just a little shorter to seat further down. The 1942s seem to be just about 12mm too long, body of the 1942 is 374mm long. Tried getting info from a few places including Koni but no luck. Thanks |
framos914 |
May 16 2019, 10:23 AM
The tab has two sides, I think on the original the shaft gets pushed down manually and catches on something to make ride adjustments. Next I'll take the strut completely out to have a good look in the housing and make there's nothing inside the housing
Lo-Fi Version | Time is now: 4th May 2024 - 06:33 AM |
