911S strut assemblies, Inserts don't fit |
framos914 |
May 14 2019, 09:31 PM
Member Group: Members Posts: 125 Joined: 15-May 14 From: Corona California Member No.: 17,353 Region Association: Southern California |
Need help. My 75 2.0 has worn strut inserts, PO replaced front struts with what I believed were 1977 911S Koni struts part #911 341 079 16 stamped on it. Bought inserts Koni 86-1942. Problem is they bottom out before going in far enough to secure them with the round nut.
Could I have 72-74 911S struts? Did they have the same part number? And are those inserts (86-1638) just a little shorter to seat further down. The 1942s seem to be just about 12mm too long, body of the 1942 is 374mm long. Tried getting info from a few places including Koni but no luck. Thanks |
sixnotfour |
May 17 2019, 01:36 AM
914 Wizard Group: Members Posts: 10,419 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Question: What a rip, my 911 has original Koni struts and many places are telling me the only thing I can install are hydraulic, standard adjustable Koni inserts. Seems strange that I have the wiz bang original Koni strut and I can't even use Koni's externally adjustable gas insert.
Answer: This used to be true. We were able to modify the gas insert to fit original Koni struts (at extra cost) but recently Koni made everyone's life much easier. A change in the design of the insert will now allow you to utilize the externally adjustable gas insert in your original Koni strut. You do have to use the correct production date insert though. |
Lo-Fi Version | Time is now: 4th May 2024 - 06:27 AM |
