Wacky Wipers, Wipers operating opposite / won't stay on |
mtc911 |
May 15 2019, 07:24 PM
Member Group: Members Posts: 65 Joined: 18-March 18 From: Atlanta Member No.: 21,978 Region Association: South East States |
Trying to figure out a weird one.
1 _ wiper Switch in down position (should be off) Wipers operate in intermittent mode 2 - wiper switch up in any of the other positions (assume should be low and high) they do nothing So the relay is engaging intermittent when they should be "Off" and when they should be going at speed in the upper positions i get nothing. Could it be a bad switch on the steering column? Or could it potentially be an incorrect switch? I know the intermittent relay was an option at one point. Any help is appreciated. Thanks |
914Sixer |
May 16 2019, 11:14 AM
914 Guru Group: Members Posts: 8,876 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
75 takes a different type of wiper switch. Has smaller base.
mtc911 |
May 16 2019, 01:35 PM
75 takes a different type of wiper switch. Has smaller base. Yeah, I saw that...tryign to figure out if the one on there is the correct one or not....Here is a pic of the bottom with a part number...crazy thing is that part number shows up as ignition switch in most places i look...not a wiper switch...so not sure if it's the correct switch or not... 914 613 306 18 |
Lo-Fi Version | Time is now: 8th May 2024 - 08:15 PM |
