Wacky Wipers, Wipers operating opposite / won't stay on |
mtc911 |
May 15 2019, 07:24 PM
Member Group: Members Posts: 65 Joined: 18-March 18 From: Atlanta Member No.: 21,978 Region Association: South East States |
Trying to figure out a weird one.
1 _ wiper Switch in down position (should be off) Wipers operate in intermittent mode 2 - wiper switch up in any of the other positions (assume should be low and high) they do nothing So the relay is engaging intermittent when they should be "Off" and when they should be going at speed in the upper positions i get nothing. Could it be a bad switch on the steering column? Or could it potentially be an incorrect switch? I know the intermittent relay was an option at one point. Any help is appreciated. Thanks |
914Sixer |
May 16 2019, 03:34 PM
914 Guru Group: Members Posts: 8,876 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
NLA switch for a long time. 75 VW Rabbit will interchange. They are rare also. I backdated my column to a 74 and used the 75 ignition switch. Easy swap.
76-914 |
May 16 2019, 06:16 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,495 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
NLA switch for a long time. 75 VW Rabbit will interchange. They are rare also. I backdated my column to a 74 and used the 75 ignition switch. Easy swap. That would be worthy of a write up Mark @914Sixer (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 8th May 2024 - 01:45 AM |
