First stop on the diagnosis train: asking the forum., 1911 sounds like marbles in a tin can. |
Optimusglen |
May 15 2019, 11:56 PM
Senior Member Group: Members Posts: 908 Joined: 26-February 16 From: Minneapolis Member No.: 19,709 Region Association: Upper MidWest |
A recent occurrence, I'm getting a pretty loud rattle that sounds like marbles swirling around the bottom of a tin can. Everything else seems fine, power etc. Hear it while in neutral and idling and also while driving in gear. It's drown out by wind noise the faster you go.
Engine is a 1.7 punched up to 1911 on dual Weber 40's. Heat exchangers stripped to bare headers, new muffler. Oil pressure and cylinder head temp both normal. |
Optimusglen |
May 17 2019, 07:56 AM
Parked it until I can dive into it more. The pulley on the alternator had some slop even though the bolt was tight, so that will be the next thing I look into and pull the belt and see how it sounds. I'll also check the exhaust since I did recently install a new aftermarket muffler and since you mentioned exhaust leak, no harm in checking it out.
Lo-Fi Version | Time is now: 17th May 2024 - 12:18 PM |
