First stop on the diagnosis train: asking the forum., 1911 sounds like marbles in a tin can. |
Optimusglen |
May 15 2019, 11:56 PM
Senior Member Group: Members Posts: 908 Joined: 26-February 16 From: Minneapolis Member No.: 19,709 Region Association: Upper MidWest |
A recent occurrence, I'm getting a pretty loud rattle that sounds like marbles swirling around the bottom of a tin can. Everything else seems fine, power etc. Hear it while in neutral and idling and also while driving in gear. It's drown out by wind noise the faster you go.
Engine is a 1.7 punched up to 1911 on dual Weber 40's. Heat exchangers stripped to bare headers, new muffler. Oil pressure and cylinder head temp both normal. |
Optimusglen |
May 25 2019, 09:50 PM
Fun stuff. And not fun stuff.
Ordered a new alternator, just the regular 55w one. Spent the afternoon swapping it in. In the process of pulling the old one out an ACORN fell out of it. Screwy. But, the pulley was loose even though the bolt was tightened down, the key was a bit mangled and the slot in the old alternator shaft was even more mangled so it was good I had a new one. Got everything buttoned up, went to connect the battery and suddenly there's billowing smoke. :[ Pull the battery cable and push it out into the driveway. Later climbed under and the alt harness is melty goo. Guessing a short to the alt back plate? New harness from 914Rubber on order. Anyone know if that type of thing would fry other components? Oh, and I installed a new alt cooling snorkle. The spring clip unsprung into the fan housing. Anyone with a good method of removing it? |
mcswiggs |
May 26 2019, 01:10 AM
Newbie Group: Members Posts: 22 Joined: 31-January 18 From: London, UK Member No.: 21,845 Region Association: England |
Take the back plate off and check the length of the terminal studs and how close they are to that back plate when assembled. I know this is a problem on new alternators sold in the UK to bus owners. Good luck. Fun stuff. And not fun stuff. Ordered a new alternator, just the regular 55w one. Spent the afternoon swapping it in. In the process of pulling the old one out an ACORN fell out of it. Screwy. But, the pulley was loose even though the bolt was tightened down, the key was a bit mangled and the slot in the old alternator shaft was even more mangled so it was good I had a new one. Got everything buttoned up, went to connect the battery and suddenly there's billowing smoke. :[ Pull the battery cable and push it out into the driveway. Later climbed under and the alt harness is melty goo. Guessing a short to the alt back plate? New harness from 914Rubber on order. Anyone know if that type of thing would fry other components? Oh, and I installed a new alt cooling snorkle. The spring clip unsprung into the fan housing. Anyone with a good method of removing it? (IMG:style_emoticons/default/dry.gif) |
Lo-Fi Version | Time is now: 16th May 2024 - 07:03 PM |
