First stop on the diagnosis train: asking the forum., 1911 sounds like marbles in a tin can. |
Optimusglen |
May 15 2019, 11:56 PM
Senior Member Group: Members Posts: 909 Joined: 26-February 16 From: Minneapolis Member No.: 19,709 Region Association: Upper MidWest |
A recent occurrence, I'm getting a pretty loud rattle that sounds like marbles swirling around the bottom of a tin can. Everything else seems fine, power etc. Hear it while in neutral and idling and also while driving in gear. It's drown out by wind noise the faster you go.
Engine is a 1.7 punched up to 1911 on dual Weber 40's. Heat exchangers stripped to bare headers, new muffler. Oil pressure and cylinder head temp both normal. |
Optimusglen |
May 28 2019, 08:18 AM
No 911 valve adjusters.
Back onto the alternator discussion. I may have hooked the alternator condenser up to the wrong post when replacing it this past weekend. (IMG:style_emoticons/default/chair.gif) I have yet to pull it out, but thinking back it is possible. The new alt had longer posts and I knew enough to cut those down. The alternator wiring harness was old and not in the best shape but looked to be solid and in one piece, and since it was working well before I didn't swap it out. I suppose another possibility is that the harness cracked and created a short while I was moving it around during removal/installation. Either way, from my initial review it looks like there was a short and it melted the harness. I already ordered a new harness from 914 Rubber. From my research it is likely the alternator is toast too. I'm hoping those and some self respect, if I did miswire it, are the only casualties here. |
Lo-Fi Version | Time is now: 20th May 2024 - 11:34 PM |
