Tips on getting the first gear teeth off? |
Tdskip |
May 17 2019, 05:24 PM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Hi guys-happy Friday. I was hoping to get some coaching on how to get the dog teeth off this first gear Assembly, they are incredibly worn down. No wonder the box jumped at it first
dr914@autoatlanta.com |
May 17 2019, 05:30 PM
914 Guru Group: Members Posts: 7,864 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
KevinW |
May 17 2019, 06:20 PM
Newbie Group: Members Posts: 42 Joined: 25-May 15 From: Winona, Minnesota Member No.: 18,761 Region Association: Upper MidWest |
I used a wood chisel, I was able to get underneath the dog teeth
Front yard mechanic |
May 17 2019, 06:52 PM
Senior Member Group: Members Posts: 1,163 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None |
I also used a wood chisel to find my datum line
Tdskip |
May 17 2019, 08:40 PM
Thanks gentlemen, I’ve been reluctant to go to hard after it because I don’t want to damage the larger piece but let me see if I can cut a relief into it and get it off that way.
It looks like the new one just presses into place and has a mechanical tension fit? |
Valy |
May 17 2019, 11:16 PM
Senior Member Group: Members Posts: 1,675 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
Thanks gentlemen, I’ve been reluctant to go to hard after it because I don’t want to damage the larger piece but let me see if I can cut a relief into it and get it off that way. It looks like the new one just presses into place and has a mechanical tension fit? https://www.amazon.com/gp/aw/d/B0722LW5RW/r...=UTF8&psc=1 |
Chi-town |
May 17 2019, 11:39 PM
Senior Member Group: Members Posts: 850 Joined: 31-August 18 From: Disneyland Member No.: 22,446 Region Association: Southern California |
^^ this is the proper tool
Tdskip |
May 18 2019, 08:23 AM
Thanks for the link-always good to have a reason to buy a new tool.
So I’m assuming that that has a lip which catches the outside of the dog teeth to pull it out and away from the rest of the gear? |
Tdskip |
May 18 2019, 08:36 AM
Ordered it - any of the local SoCal 914 mafia is welcome to borrow it as helpful.
Montreal914 |
May 18 2019, 11:46 AM
Senior Member Group: Members Posts: 1,560 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
Propably too late... P225 tool.
Part of the tool list you need to rebuild your gearbox. Add Dr Evil's video and have fun. (IMG:style_emoticons/default/smash.gif) Good luck with your project (IMG:style_emoticons/default/beerchug.gif) |
Tdskip |
May 18 2019, 12:00 PM
Thanks - looks like a quite different design than the other one.
Tdskip |
May 31 2019, 09:25 AM
ChrisFoley |
May 31 2019, 09:31 AM
I am Tangerine Racing Group: Members Posts: 7,925 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
You really need the tool shown above or a well made facsimile. The tooth rings can be broken easily because of the metal hardness if the loads aren't spread out across the entire circumference of the ring.
Tdskip |
May 31 2019, 09:50 AM
Hi Chris - thanks for the response.
The dog teeth on there are scrap so not very concerned about saving them, but are you saying the main gear might be damaged too? |
ChrisFoley |
May 31 2019, 10:25 AM
Hi Chris - thanks for the response. The dog teeth on there are scrap so not very concerned about saving them, but are you saying the main gear might be damaged too? That gear spreader will almost surely damage the main gear if you try to force it between the tooth ring and the gear. |
Tdskip |
May 31 2019, 10:27 AM
Yikes.
So how does the proper Porsche tool will work so how does the proper Porsche tool work? It’s not jumping out at me on how it would separate the dog teeth from the main gear. Thanks |
Montreal914 |
May 31 2019, 12:31 PM
Post #10 (IMG:style_emoticons/default/biggrin.gif)
First, get Dr Evil's video, get a beer and enjoy the first watching. Then get the tools and parts. Finally, bring the laptop to the garage, cover it with saran wrap, hit play/pause and rebuild along! Good luck with your fun and rewarding project! (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/smash.gif) |
Tdskip |
May 31 2019, 01:39 PM
I am assuming that took holds the dog teeth and he you press the main gear down and away?
Montreal914 |
May 31 2019, 02:32 PM
Look at this video...
at 3 minutes, he starts to use the tool. https://www.youtube.com/watch?v=K5e2qlcZWZs How's the rest of the box? 1st -2nd dogteeth and 1st slider, 2-3rd slider? What are you using for gasket to close back up the box? The thickness has an influence on the pinion depth for the final drive. Again, no affiliation, but the Dr. video has a lot of very good information. Just saying... (IMG:style_emoticons/default/poke.gif) |
76-914 |
May 31 2019, 04:15 PM
I used to loan my tool out. The last time I loaned it out was the last time, too. He loaned it to a, get this, 914 mechanic who proceeded to strip the synchronizers off his stock pile of gears. (IMG:style_emoticons/default/ar15.gif) Of course it came back with hammer marks all over it. (IMG:style_emoticons/default/headbang.gif) I don't blame the kid that originally borrowed it as he was young and working for the guy. What was he going to tell his Boss; NO? Some people. Anyway, that professional 914 mechanic went out of business 2 years later. Gee, I wonder why? (IMG:style_emoticons/default/lol-2.gif) Rant over.
Lo-Fi Version | Time is now: 17th May 2024 - 04:43 PM |
