1975 1.8 FI fuel pump not working |
John90290 |
May 19 2019, 12:42 PM
Member Group: Members Posts: 93 Joined: 4-March 18 From: Ventura, CA Member No.: 21,937 Region Association: None |
Putting car back together after rebuild. Ran before I took it apart. Ran through the checklists I’ve found online so relay board is good. Pump works when I put yellow wire from 12 pin connector on terminal III so wiring to pump is good. What I don’t get is the 1.5 second run time when I turn the key or have pump running when I crank motor. No 1.5 on terminal 87 when I turn key on either. Check list says bad relay but I replaced with one from headlights that I know works. Stuck.
I used this checklist. http://bowlsby.net/914/Classic/zTN_FI_FPChecklist2.pdf Attached thumbnail(s) |
jim912928 |
May 19 2019, 12:47 PM
Senior Member Group: Members Posts: 1,485 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest |
Pump won’t turn on unless the air intake flapper (not sure that is what it is called) in the AFM opens with the intake of air when cranking. It may be stuck from sitting. Take the air filter off and prop open that flapper then give it a crank. This is specific to l-jet. Had the same issue with my 75 1.8l.
914fahrer |
May 19 2019, 01:30 PM
Member Group: Members Posts: 103 Joined: 12-November 14 From: Berlin/Germany Member No.: 18,115 Region Association: Germany |
If the car is original ,you have a l-jetronic not a D-jetronic.Use a checklist for the l-jetronic.I would check first the dual relay, it is under the Battery if I remember me correct.
John90290 |
May 19 2019, 06:22 PM
If the car is original ,you have a l-jetronic not a D-jetronic.Use a checklist for the l-jetronic.I would check first the dual relay, it is under the Battery if I remember me correct. That explains a lot. Tried testing the relay but went ahead and bought a new on. The 40 year old one looks pretty bad. I will let you know what happens. |
Lo-Fi Version | Time is now: 16th May 2024 - 09:00 PM |
