Putting car back together after rebuild. Ran before I took it apart. Ran through the checklists I’ve found online so relay board is good. Pump works when I put yellow wire from 12 pin connector on terminal III so wiring to pump is good. What I don’t get is the 1.5 second run time when I turn the key or have pump running when I crank motor. No 1.5 on terminal 87 when I turn key on either. Check list says bad relay but I replaced with one from headlights that I know works. Stuck.
I used this checklist.
http://bowlsby.net/914/Classic/zTN_FI_FPChecklist2.pdf
