Lean |
Lean |
StratPlayer |
May 19 2019, 02:32 PM
StratPlayer Group: Members Posts: 3,264 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
Car is running lean, how to richen it up
porschetub |
May 19 2019, 02:48 PM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Rand |
May 19 2019, 02:56 PM
QUOTE how to richen it up More fuel? (IMG:style_emoticons/default/tongue.gif) I think someone is pulling our leg. I inserted a new foot pedal so his guitar will sound funny until he turns the right knobs. |
rhodyguy |
May 19 2019, 03:10 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,061 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Factory Djet. Not sure on the dist.
StratPlayer |
May 19 2019, 05:56 PM
Factory DJet 123 dizzy 2056
Rand |
May 19 2019, 06:00 PM
Is it lean across the rpm range, or just idle?
StratPlayer |
May 19 2019, 06:46 PM
lean under load, ie: climbing a hill, CHT temp soars to the dangerous range. I have a dakota digital CHT gauge installed thot's I can say the dangerous range. I have the cooling flaps open for summer driving.
I just opened them up last week when I saw those CHT temps soaring under load. Speed 75 5th gear rpm 3100. will pull the plugs tomorrow to inspect them. Running lean |
76-914 |
May 19 2019, 07:03 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,490 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Jim, if it only happens during a climb out on the Hi-Way I'd suspect the MPS needs a little adjustment on the full load. It's been so damned long since I futzed with D-Jet but IIRC there is an adjustment for the full load "only" side. One of the adjustments effect both ends and I forget but maybe there is also a 3rd function. Drop it off at Eric's. (IMG:style_emoticons/default/biggrin.gif)
StratPlayer |
May 19 2019, 07:22 PM
Eric and I discussed this, car will going in next week.
JRust |
May 19 2019, 08:49 PM
914 Guru Group: Members Posts: 6,305 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
Man for some reason when your motor went last time. I thought you went crazy & had Eric throw a 6 in there
StratPlayer |
May 29 2019, 03:24 PM
Update: Well the car went into PMB to find the lean issue. The following photo's are courtesy of PMB. The MPS had to be rebuilt, someone was in there before and solder a bead to try and stop it from leaking of course at that time there were no rebuilt kits for the MPS. The big culprit turned out to be the plenum as you will see in the pics. The plenum was tig welded completely, cracks everything.. Air Sucking Bitch. Thanks to my dakota digital CHT gauge it saved this engine from some serious damage. It's a new build as well.
Cylinder #3 CHT gauge attached to it. Attached image(s) |
76-914 |
May 29 2019, 04:57 PM
Shit. That plenum was a leaker. I'll bet it pulls better now.
johnlush |
May 29 2019, 07:47 PM
What's all this then? Group: Members Posts: 371 Joined: 26-May 04 From: Cheyenne, WY Member No.: 2,108 Region Association: Rocky Mountains |
Kudos to you for spotting the issue and getting it addressed before it caused serious issues. Refinished plenum looks awesome! (IMG:style_emoticons/default/beerchug.gif)
jim_hoyland |
May 30 2019, 05:49 AM
Get that VIN ? Group: Members Posts: 9,262 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Way to go (IMG:style_emoticons/default/smile.gif) Great analysis and quick results.
Lo-Fi Version | Time is now: 26th April 2024 - 01:29 PM |
