A question about the factory backpad, Is there a good way to raise it a bit? |
horizontally-opposed |
May 19 2019, 08:44 PM
Advanced Member Group: Members Posts: 3,431 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None |
So my 914's backpad sits just below the rubber seal on the engine lid side of the rear glass—creating an ugly eye into the space under said seal as well as the butyl tape. In the past, I've hidden that gap with electrical tape "artfully" placed, but it ain't pretty.
Looks like I am not the first to do so… http://www.914world.com/bbs2/index.php?sho...&hl=backpad Wondering if there is a better way. Has anyone moved the backed up a bit to sit high enough to match up with the engine lid seal on the other side of the back window? Thanks!! |
May 21 2019, 12:35 PM
^ Nice setup! Been thinking about a similar LED, but mounted to the vinyl pad above the rear window and possibly "shielded" to throw most of its light down and forward. Would simply extend the factory wiring up and around to that area of the interior so it goes on/off with the doors. Not sure about a switch, but that would make Larmo's idea of the 911 rocker dome light a good one if that can be fit. Or maybe an LED light that functions similarly and is subtle?
Where did you get the LED, if I may ask? |
mlmgm |
May 21 2019, 11:15 PM
Newbie Group: Members Posts: 35 Joined: 5-January 08 From: California Member No.: 8,536 Region Association: Northern California |
^ Nice setup! Been thinking about a similar LED, but mounted to the vinyl pad above the rear window and possibly "shielded" to throw most of its light down and forward. Would simply extend the factory wiring up and around to that area of the interior so it goes on/off with the doors. Not sure about a switch, but that would make Larmo's idea of the 911 rocker dome light a good one if that can be fit. Or maybe an LED light that functions similarly and is subtle? Where did you get the LED, if I may ask? LED light came from these folks: https://www.superbrightleds.com/moreinfo/le...ttributes/10916 We do have the light on a small switch, left front of the fire extinguisher |
Lo-Fi Version | Time is now: 10th May 2024 - 05:49 AM |
