914-4 AGM Battery, Proper Fit |
atomicscott |
May 20 2019, 09:42 PM
Newbie Group: Members Posts: 4 Joined: 18-July 18 From: Chicago, Illinois Member No.: 22,323 Region Association: Upper MidWest |
There was discussion about the best agm battery to use in a 914-4. Someone mentioned the Optima Red Top 34R being a good choice, but their website says that this battery will not fit. Can anyone advise what AGM battery they have used in their 914 with no fit problem? Thank you for your help!
mtndawg |
May 20 2019, 10:50 PM
Member Group: Members Posts: 413 Joined: 26-January 09 From: Granite Bay, Ca Member No.: 9,985 Region Association: None |
I just put in an odyssey with Patrick motor sports hold down. Looks really nice and fits perfectly.
oakdalecurtis |
May 20 2019, 10:55 PM
Oakdalecurtis Group: Members Posts: 1,324 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California |
I use the 34r with no problems, fits easily...
Rand |
May 20 2019, 10:58 PM
Odyssey PC680 is my favorite. Small, light, works. Next time I buy though, I will be looking at lithium ion. It's getting there for cars, and they are crazy light weight for their power.
Mark Henry |
May 21 2019, 06:17 AM
I have a PC 680 in my car not much bigger than a motorcycle battery, only complant is it won't turn over a new engine for break in.
To me a better choice for a DD or every weekend car would be the PC925, still almost half the size and weight of a regular battery. A full size AGM is overkill. |
windforfun |
May 21 2019, 08:44 AM
Senior Member Group: Members Posts: 1,778 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
Would someone please post a pic of this AGM battery.
Mark Henry |
May 21 2019, 08:50 AM
Here's a pic that's not super clear. I used three pieces of tape - 6" long pieces on either side for a nice flush fit & then one long continuous piece centered in the middle. (IMG:style_emoticons/default/agree.gif) the picture is hard to see. (IMG:style_emoticons/default/biggrin.gif) |
Chi-town |
May 21 2019, 09:26 AM
Would someone please post a pic of this AGM battery. https://www.odysseybattery.com/Batteries/Model_PC925 You can use the PMS or Rennline battery mount kit. Optima are junk, they started using recycled lead about 10 years ago and the warranty rate went through roof. I worked at one of the top 3 Optima retailers in the US. |
napasteve |
May 21 2019, 09:47 AM
914 driving winemaker Group: Members Posts: 501 Joined: 2-January 13 From: Napa, CA Member No.: 15,327 Region Association: Northern California |
windforfun |
May 21 2019, 10:02 AM
This Optima battery is about ten years old & works just fine. FYI.
Attached thumbnail(s) |
oakdalecurtis |
May 21 2019, 10:19 AM
bbrock |
May 21 2019, 11:22 AM
Has anyone tried a Group 47 battery in a 914? Same footprint as Group 42 but 15mm taller. I'm guessing it hits the rain tray but curious because Bosch makes an AGM battery in that size.
914forme |
May 21 2019, 12:16 PM
(IMG:style_emoticons/default/confused24.gif) You want it for period correct Look?
They make covers for the Optimas Odedessy Even Delco and Deka that make it look like the old lead acids, if you are going period look. Tar Topper Make Modren Starting Power look period correct |
bbrock |
May 21 2019, 03:32 PM
Not necessarily. More just curious about other size options. I do like that Bosch have bottom hold downs molded in though. I'm not crazy about the look or price of the battery hold down kits. Not an issue with Optima I don't think and I have one in my work rig/snow plow that has been bombproof through more than 10 Montana winters, but I've read several places that their quality has gone to (IMG:style_emoticons/default/stromberg.gif) |
porschetub |
May 21 2019, 04:07 PM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Funny little Chinese Vision AGM still going strong after a long time (4yrs),cheap and only 9lbs,hell @ less than $80 to buy and with that weight you could carry a spare.
Sold as a racecar battery in my country but plenty of cranking power for my six. I have since built a custom battery tray for it which is future proofed to the next larger size if needs be. |
mepstein |
May 21 2019, 04:12 PM
914-6 GT in waiting Group: Members Posts: 19,254 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Not necessarily. More just curious about other size options. I do like that Bosch have bottom hold downs molded in though. I'm not crazy about the look or price of the battery hold down kits. Not an issue with Optima I don't think and I have one in my work rig/snow plow that has been bombproof through more than 10 Montana winters, but I've read several places that their quality has gone to (IMG:style_emoticons/default/stromberg.gif) I've had good luck with Optima's. I keep it on a battery tender jr. The guys at the shop "borrowed" one of my Optima's to start a car. It was low so they put it on a fast charger set to 11. Blew out a cell in the battery. I think following the directions for the Optima's is really important. I am going to experiment with some ATV lithium batteries since they are super light and seem to work ok. Quick way to loose 30 lbs. |
burton73 |
May 21 2019, 04:13 PM
burton73 Group: Members Posts: 3,510 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
Not necessarily. More just curious about other size options. I do like that Bosch have bottom hold downs molded in though. I'm not crazy about the look or price of the battery hold down kits. Not an issue with Optima I don't think and I have one in my work rig/snow plow that has been bombproof through more than 10 Montana winters, but I've read several places that their quality has gone to (IMG:style_emoticons/default/stromberg.gif) That was a few years ago. They say at my local distributor it was a bad factory in Mexico and that they have fixed it up now. Just have to cut off a tab that is not needed making the battery case on the base too long by 3/8 or so They were very good 15 years ago. I put one in my 76 car a few years ago and all good. Bob B |
porschetub |
May 21 2019, 04:21 PM
napasteve |
May 21 2019, 04:38 PM
I just bought a cutoff switch from Amazon
https://www.amazon.com/gp/product/B007O0BBF...=UTF8&psc=1 I made the box from a plastic outlet box and cover. |
Cal |
May 21 2019, 06:06 PM
Senior Member Group: Members Posts: 615 Joined: 19-November 14 From: Philadelphia Member No.: 18,138 Region Association: North East States |
I'm currently running the Bosch 96R size battery and it fits perfect. I've had it for three years with no issues. It's connected to a battery tender in the off season.
Attached image(s) |
Lo-Fi Version | Time is now: 3rd May 2024 - 10:51 PM |
