| StarBear |
May 21 2019, 06:26 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,219 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States
Yep; just put an Optimum Red 34R. THey new come with all sorts of adaptors; fit perfectly (though I preferred to shave a bit off each bottom side to slide in/out of the battery tray a bit more easily. The hold-down clamp (4-5 options included in each one) is great. Just make sure you get a fresh one - lots of old ones still on shelves....
| saigon71 |
May 21 2019, 06:34 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,019 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region
A word of caution for those with the factory rain tray looking to buy an Optima. Buy the 34 (NOT R). It puts the posts on the outboard side of the battery so the decklid will close without interference.
| porschetub |
May 22 2019, 12:01 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,969 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
The biggest benefit with a AGM is the low discharge rate ,ideal for a weekend car or garage queen that has little use ,battery tech has come a long way so we don't need to carry around 30+ pounds of extra weight with a wet cell.
Downsides...mine has a really small 6mm bolt post setup,I have adapted to that but a pain,they DO not like being run really flat and for that reason they will not last as long. My main point is you don't need to spend a bunch on a suitable battery (IMG:style_emoticons/default/beerchug.gif) . |
Lo-Fi Version | Time is now: 7th December 2025 - 11:29 AM |
