914-6 speedo inop, Just bought 914-6 recreation trans flipped speedo inop |
EXBOXR |
May 22 2019, 03:42 PM
Newbie Group: Members Posts: 2 Joined: 8-May 19 From: Northern California Member No.: 23,108 Region Association: None |
Hi gang, I just bought a 914-6 recreation and the previous owner had the transmission
Flipped, So I guess the cable does not reach. So what has been your experience with Making it work. I hear there is a GPS version that looks pricey. Thank you for the help. I feel like I'm speeding to much. I live in Santa Rosa CA. I see that there are 914 guys in Petaluma. Ron |
Luke M |
May 22 2019, 04:58 PM
Senior Member Group: Members Posts: 1,372 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
(IMG:style_emoticons/default/welcome.png) It looks like a 915 with a Vellios kit installed if that's the trans/engine pic you posted. It may require a electronic speedo and associated hardware to make it all work.
The 915's with the electric speedo had a sensor mounted on the side cover. Take a better pic of that and post it here to confirm. |
porschetub |
May 22 2019, 07:03 PM
Advanced Member Group: Members Posts: 4,701 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
(IMG:style_emoticons/default/welcome.png) It looks like a 915 with a Vellios kit installed if that's the trans/engine pic you posted. It may require a electronic speedo and associated hardware to make it all work. The 915's with the electric speedo had a sensor mounted on the side cover. Take a better pic of that and post it here to confirm. Yep that's the one,always wondered about flipping a 915,presume it works obviously with no lubrication issues otherwise someone would have only done it once (IMG:style_emoticons/default/biggrin.gif) . Seemed to remember there is a kit that mounts above CV with a optical sensor and trigger wheel however think I saw it on Pelican and it was for a 911. Crazy looking car with those huge flares...... |
mepstein |
May 22 2019, 07:17 PM
914-6 GT in waiting Group: Members Posts: 19,274 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
(IMG:style_emoticons/default/welcome.png) It looks like a 915 with a Vellios kit installed if that's the trans/engine pic you posted. It may require a electronic speedo and associated hardware to make it all work. The 915's with the electric speedo had a sensor mounted on the side cover. Take a better pic of that and post it here to confirm. Yep that's the one,always wondered about flipping a 915,presume it works obviously with no lubrication issues otherwise someone would have only done it once (IMG:style_emoticons/default/biggrin.gif) . Seemed to remember there is a kit that mounts above CV with a optical sensor and trigger wheel however think I saw it on Pelican and it was for a 911. Crazy looking car with those huge flairs...... They flipped the diff, not the entire trans. |
porschetub |
May 22 2019, 09:17 PM
(IMG:style_emoticons/default/welcome.png) It looks like a 915 with a Vellios kit installed if that's the trans/engine pic you posted. It may require a electronic speedo and associated hardware to make it all work. The 915's with the electric speedo had a sensor mounted on the side cover. Take a better pic of that and post it here to confirm. Yep that's the one,always wondered about flipping a 915,presume it works obviously with no lubrication issues otherwise someone would have only done it once (IMG:style_emoticons/default/biggrin.gif) . Seemed to remember there is a kit that mounts above CV with a optical sensor and trigger wheel however think I saw it on Pelican and it was for a 911. Crazy looking car with those huge flairs...... They flipped the diff, not the entire trans. Whoops ,teach me to read first (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) |
Lo-Fi Version | Time is now: 19th May 2024 - 01:28 AM |
