Turn signal reinstall, Doesn’t fit |
Wew |
May 22 2019, 07:55 PM
Member Group: Members Posts: 227 Joined: 17-January 15 From: Novato, ca Member No.: 18,335 Region Association: None |
Hi all,
Installing new switches into steering column and also did the electric motor pump washer upgrade. I am having a heck of a time getting both of the windshield wiper and turn signal wire housings to fit back through the steering column channel. There has to be something I am doing wrong. Anyone with any experience doing this, your feedback and help is much appreciated. Thank you, Gary |
dr914@autoatlanta.com |
May 23 2019, 08:10 AM
914 Guru Group: Members Posts: 7,866 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
you will have to use the wire channel from your old switch and stagger the extra wire on top. A direct fit on the 75 76 models however but not on the 72-74
Wew |
May 23 2019, 08:37 AM
you will have to use the wire channel from your old switch and stagger the extra wire on top. A direct fit on the 75 76 models however but not on the 72-74 Hi all, Thanks much for the input. Much appreciated. (IMG:style_emoticons/default/pray.gif) |
Lo-Fi Version | Time is now: 19th May 2024 - 09:20 PM |
