Turn signal reinstall, Doesn’t fit |
Wew |
May 22 2019, 07:55 PM
Member Group: Members Posts: 227 Joined: 17-January 15 From: Novato, ca Member No.: 18,335 Region Association: None |
Hi all,
Installing new switches into steering column and also did the electric motor pump washer upgrade. I am having a heck of a time getting both of the windshield wiper and turn signal wire housings to fit back through the steering column channel. There has to be something I am doing wrong. Anyone with any experience doing this, your feedback and help is much appreciated. Thank you, Gary |
jcd914 |
May 22 2019, 10:22 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
The new wiper switch you are using has the electrical contacts for the washer pump and so it has a different wire guide for the extra wires. It is too wide to fit in the steering column.
The plastic wire guide from the old wiper switch has to be transferred to the new wiper switch. You end up with the wires in the same slots. Jim |
worn |
May 23 2019, 02:43 AM
can't remember Group: Members Posts: 3,153 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
The new wiper switch you are using has the electrical contacts for the washer pump and so it has a different wire guide for the extra wires. It is too wide to fit in the steering column. The plastic wire guide from the old wiper switch has to be transferred to the new wiper switch. You end up with the wires in the same slots. Jim I haven’t done this for a few years but I seem to remember that you end up with the washer pump wires not fitting the old plastic loom and having to go through loose. Not too easily either. The pump wires also need separate connections to non original wires that one runs to the pump. |
Lo-Fi Version | Time is now: 8th May 2024 - 09:54 AM |
