Engine Re-Seal Guidance, What to replace and where to buy |
tvdinnerbythepool |
May 23 2019, 03:39 PM
Member Group: Members Posts: 310 Joined: 24-July 18 From: Olympia, WA Member No.: 22,336 Region Association: Pacific Northwest |
Hey all,
Whilst the engine is out and I repair the hell hole, I’d like to re-seal the engine. Definitely leaking and making a mess in the garage as well as the cloud of smoke as it warms up and the HEs cook off the fresh drips. I am new to the type IV and was wondering if you guys could give me a list of... -what seals there are to be replaced? -Order in which to replace? -recommendations on kits or vendors for needed seals? Thanks for the guidance! It’s greatly appreciated (IMG:style_emoticons/default/welder.gif) |
mark04usa |
May 23 2019, 03:58 PM
'70 1.7 Tangerine Group: Members Posts: 351 Joined: 14-September 09 From: Austin TX Member No.: 10,805 Region Association: Southwest Region |
I resealed my '70 1.7 a couple of years ago. Plan to replace oil cooler seals and push rod tube seals with valve cover gaskets. On the top side, oil pressure switch is a common leaker. Good time to replace leaking trans seals as well.
Since your car is an early 1.7, be aware that it likely needs the smaller diameter push rod tube seals (on the cyl head end IIRC). It can be hard to find the correct push rod tube seals for early 1.7, and few of our parts suppliers are aware of the difference. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 07:37 PM |
