clutch slipping |
clutch slipping |
ruddyboys |
Jun 25 2005, 11:31 AM
Hummel eigentümer Group: Members Posts: 594 Joined: 3-March 04 From: Monroe, NY Member No.: 1,749 Region Association: North East States |
Clutched seemed fine (never realloy dove it far). I put the foot board in and I would grind gears while engaging. I adjusted the clutch cable and the grinding almost stopped (really only when putting in reverse). I took the car out and all seemed fine, then it seemed the clutch was sliping a little, then a whole lot. Is it just in need of adjustment or new clutch.
redshift |
Jun 25 2005, 11:35 AM
So you tighten it, it works, then it starts failing, so you tighten it, and ..
Clutch cable is about to snapola. Also, when you put a new cable in, adjust it so there is no action for 3/4 of an inch, then the clutch starts disengaging.. and there should be room at the of pedal on the other end of play, where it's floating, and completely disengaged, before the stop. M |
Cap'n Krusty |
Jun 25 2005, 12:07 PM
BETTER CHECK THE CLUTCH TUBE, TOO!!!!!! Common failure, with just the symproms you describe. Also look at the roll pin in the clutch pedal. The Cap'n
Joe Bob |
Jun 25 2005, 12:10 PM
Tube....
redshift |
Jun 25 2005, 02:33 PM
-sigh-
I disagree with Miles, I think it's the tube. (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) M |
Lo-Fi Version | Time is now: 21st May 2024 - 10:27 PM |
