While we are on the topic of injectors! |
Jonathan Livesay |
Jun 2 2019, 12:00 PM
Senior Member Group: Members Posts: 741 Joined: 13-March 10 From: La Canada CA Member No.: 11,461 Region Association: None |
In my box of spare FI parts I notice that I have 3 75-76 injectors (0 280 150 038) and 1 73-74 injector (0 280 150 019). Since all the stuff I have came with a 74 2.0 car or a 75 2.0 car this makes me wonder what I have on the motor in the running car. All the other components are correct for the 74. Does anyone know if there is a functional difference between the 038 and the 019 injectors and if this might cause the very minor idle issues I am still having even after chasing down just about every other possibility? That is if I in fact do have 3 019 and 1 038 injectors on the running motor.
914Sixer |
Jun 2 2019, 08:21 PM
Maybe Jeff B will chime in here. To the best of my knowledge they both operate at the same pressure. They should be interchangeable.
Jonathan Livesay |
Jun 2 2019, 08:51 PM
@jeffbowlsby ?
JeffBowlsby |
Jun 3 2019, 08:56 AM
914 Wiring Harnesses Group: Members Posts: 8,509 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Same-same. One possible difference that someone else mentioned was the notion that the later version may have a higher heat treated pintle to better withstand the higher head heats of the 75-76 cars. While plausible its only speculation.
Jonathan Livesay |
Jun 3 2019, 09:52 AM
Same-same. One possible difference that someone else mentioned was the notion that the later version may have a higher heat treated pintle to better withstand the higher head heats of the 75-76 cars. While plausible its only speculation. Thank you! (IMG:style_emoticons/default/beerchug.gif) |
dr914@autoatlanta.com |
Jun 3 2019, 10:36 AM
914 Guru Group: Members Posts: 7,864 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
AS usual Jeff, the man, comes through. I have always wondered the difference as well, thinking that the late model injectors were leaner, to control emissions, but obviously no t so
Same-same. One possible difference that someone else mentioned was the notion that the later version may have a higher heat treated pintle to better withstand the higher head heats of the 75-76 cars. While plausible its only speculation. |
JeffBowlsby |
Jun 3 2019, 03:24 PM
Aw shucks George....you've forgotten more than I will ever pretend to know about 914s...but thanks for the kudos.
914Sixer |
Jun 3 2019, 04:05 PM
As a side bar note, all 5 of the 038 injectors I have the boots are mounted side ways, not up and down like the 019. Replaced them with new AA high pressure formed boots.
Lo-Fi Version | Time is now: 17th May 2024 - 02:05 PM |
