Door Jam Support Question, Oil lines in my future? |
amfab |
Jun 2 2019, 01:46 PM
Member Group: Members Posts: 393 Joined: 17-May 16 From: Los Angeles Member No.: 20,004 Region Association: None |
I an trying to fab up supports for the bottom of the door jams (blue in the attached sketch.)
The old ones were rusty—shocking I know. I will be installing a Brad Mayeur stiffening kit (red in the attached sketch) and so I am thinking that because of the strength of this reinforcement I can probably make the door jam support a little shorter (not go to the bottom of the long). This will leave clearance for the lines if I decide to run a front oil cooler later. At this point I am thinking rear passenger fender for a cooler, but I want to get feedback on how they work from Perry Kiehl first Alternatively, I can make it go to the bottom of the long and later maybe drill holes in the side of the support if I decide on a front oil cooler. See the sketch below to visualize what I am talking about. I will build the support out of 16 ga to make it pretty hefty. My question is what is the outer diameter of the biggest oil line I could possibly need for a non-track 3.2? Thanks, -Andrew |
Jun 2 2019, 02:18 PM
I did all mine with AN 12 which most people feel is fine for a 3.2 street car. I'm pretty sure I just used a 1" bit to make all the holes along the door sill supports and the front trunk.
https://www.dragstuff.com/techarticles/AN-R...ence-Chart.html AN Fittings - Hose and Tubing Size Reference Charts by John Heard, Last Updated Dec 31, 2014 Stainless Tubing AN Equivalent All dimensions are in inches unless otherwise noted. AN Tube Size OD Thread Size Wrench Size -2 1/8" 5/16"-24 N/A -3 3/16" 3/8"-24 1/2" -4 1/4" 7/16"-20 9/16" -5 5/16" 1/2"-20 N/A -6 3/8" 9/16"-18 11/16" -8 1/2" 3/4"-16 7/8" -10 5/8" 7/8"-14 1" -12 3/4" 1 1/16"-12 1 1/4" -16 1" 1 5/16"-12 1 1/2" -20 1 1/4" 1 5/8"-12 1 7/8" -24 1 1/2" 1 7/8"-12 N/A -28 1 3/4" 2 1/4"-12 N/A -32 2" 2 1/2"-12 N/A Hose Size Chart Fractional Equivalent All dimensions are in inches unless otherwise noted. AN I.D. O.D. -4 7/32" 7/16" -6 11/32" 35/64" -8 7/16" 41/64" -10 9/16" 51/64" -12 11/16" 15/16" -16 7/8" 1 5/32" -20 1 1/8" 1 7/16" -24 1 3/8" 1 45/64" -28 1 1/2" 1 13/16" -32 1 3/4" 2 3/32" |
live free & drive |
Jun 2 2019, 05:18 PM
Member Group: Members Posts: 158 Joined: 29-June 16 From: New Hampshire Member No.: 20,159 Region Association: None |
amfab |
Jun 3 2019, 07:00 PM
You guys rock, thank you!
Lo-Fi Version | Time is now: 17th May 2024 - 02:56 PM |
