Cover for hole under Gas Tank and Seal around Steering column?, Wondering what fills the hole and gap |
sketchc13 |
Jun 5 2019, 10:12 AM
Newbie Group: Members Posts: 13 Joined: 7-February 11 From: NorCal Member No.: 12,675 Region Association: Northern California |
I have my gas tank out and under it there is a ~100mm hole on the passenger side and a gap around the boot where the steering column goes through the body on the way to the steering rack.
Is something missing? Coming from Wisconsin, the hole and gap are very inviting to garage invading squirrels to store their nuts and more in the fall and winter and it seems like something should go there.... Are there OE parts that go there or did any one fab something up for the hole and gap? See attached pic... I have since cleaned up the surface rust. Cheers, Andrew |
ndfrigi |
Jun 5 2019, 10:19 AM
914_7T3 |
Jun 5 2019, 12:52 PM
Please forgive me, I'm new to all of this! Group: Members Posts: 1,846 Joined: 3-April 17 From: Los Angeles, CA Member No.: 20,991 Region Association: Southern California |
That area stays open, however you can use the 914 Rubber welting as they came with something similar from the factory.
Literati914 |
Jun 6 2019, 12:06 AM
Senior Member Group: Members Posts: 1,437 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
914Sixer |
Jun 6 2019, 06:07 AM
914 Guru Group: Members Posts: 8,870 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Guitar hole cover from an instrument store.
IronHillRestorations |
Jun 6 2019, 06:32 AM
Yes, you can mount it to the steering rack support, just make sure there's no contact with any moving parts.
Mikey914 |
Jun 6 2019, 08:51 AM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
GregAmy |
Jun 6 2019, 08:59 AM
Advanced Member Group: Members Posts: 2,268 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
Guitar hole cover from an instrument store. I don't think you want to seal those holes. I don't know if that's what was intended with those holes, but any fuel leaks (or fill overflow) would cause a build up of fuel in there. Better to leave it open to drain and allow lquids and fumes to escape. |
NS914 |
Jun 6 2019, 09:21 AM
Member Group: Members Posts: 198 Joined: 9-June 09 From: Dartmouth, Nova Scotia Member No.: 10,455 Region Association: Canada |
bbrock |
Jun 6 2019, 09:26 AM
Guitar hole cover from an instrument store. I don't think you want to seal those holes. I don't know if that's what was intended with those holes, but any fuel leaks (or fill overflow) would cause a build up of fuel in there. Better to leave it open to drain and allow lquids and fumes to escape. The large hole might help with fumes, but there is a slotted drain hole under the large hole next to where the fuel overfill tube exits so drainage is handled in those two locations. My slotted drain was plugged with undercoating which no doubt contributed to the rust repair I had to do in the fuel compartment (IMG:style_emoticons/default/dry.gif) Make sure it's open while you're in there. |
914Sixer |
Bottom of pan has weep holes for drainage UNLESS they get plugged up with stuff.
sixnotfour |
Jun 6 2019, 01:53 PM
914 Wizard Group: Members Posts: 10,411 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
a screen would be great to mice out
sixnotfour |
Jun 6 2019, 01:55 PM
QUOTE I think I know the answer to this question but here goes....are those covers still available from anyone these days.....my car did not have one when I bought it. post a wanted in the classifieds, there are plenty around |
sketchc13 |
Jun 11 2019, 10:47 AM
Thanks Gents - no cover for the hole and a gap around the steering column boot to the bulkhead it is.
It just kinda surprises me thats the original solution cuz that steering rack cover doesn't really seal up the area from below. Definitely enough to keep the water and debris out, but not really dust and critters. Anyway, mystery solve for me. Thanks! |
bbrock |
Jun 11 2019, 12:06 PM
Thanks Gents - no cover for the hole and a gap around the steering column boot to the bulkhead it is. It just kinda surprises me thats the original solution cuz that steering rack cover doesn't really seal up the area from below. Definitely enough to keep the water and debris out, but not really dust and critters. Anyway, mystery solve for me. Thanks! Well dangit, I was hoping you'd come up with a clever solution because I agree with you this is a problem. Where I live, leaving a car outside just 30 minutes after dark is guaranteed to get rodents in the car. I've been looking at those gaping mouse portals and wondering how to deal with them myself. |
Jun 11 2019, 12:21 PM
Thanks Gents - no cover for the hole and a gap around the steering column boot to the bulkhead it is. It just kinda surprises me thats the original solution cuz that steering rack cover doesn't really seal up the area from below. Definitely enough to keep the water and debris out, but not really dust and critters. Anyway, mystery solve for me. Thanks! Well dangit, I was hoping you'd come up with a clever solution because I agree with you this is a problem. Where I live, leaving a car outside just 30 minutes after dark is guaranteed to get rodents in the car. I've been looking at those gaping mouse portals and wondering how to deal with them myself. You can’t seal most cars against mice. They can get through a 1/4-1/2” opening. |
bbrock |
Jun 11 2019, 12:51 PM
Thanks Gents - no cover for the hole and a gap around the steering column boot to the bulkhead it is. It just kinda surprises me thats the original solution cuz that steering rack cover doesn't really seal up the area from below. Definitely enough to keep the water and debris out, but not really dust and critters. Anyway, mystery solve for me. Thanks! Well dangit, I was hoping you'd come up with a clever solution because I agree with you this is a problem. Where I live, leaving a car outside just 30 minutes after dark is guaranteed to get rodents in the car. I've been looking at those gaping mouse portals and wondering how to deal with them myself. You can’t seal most cars against mice. They can get through a 1/4-1/2” opening. Yes, but that opening is particularly inviting. I'm a wildlife biologist and the shape and size of that area would make a darn good design for a nest box or shelter designed to attract many small mammals. I actually had a weasel living in that area of my car before I pulled my car out of hibernation. I like weasels, but less so in the car. I totally agree with the futility of making a car rodent "proof", but rodent "resistant" is doable. |
Jun 11 2019, 03:01 PM
Thanks Gents - no cover for the hole and a gap around the steering column boot to the bulkhead it is. It just kinda surprises me thats the original solution cuz that steering rack cover doesn't really seal up the area from below. Definitely enough to keep the water and debris out, but not really dust and critters. Anyway, mystery solve for me. Thanks! Well dangit, I was hoping you'd come up with a clever solution because I agree with you this is a problem. Where I live, leaving a car outside just 30 minutes after dark is guaranteed to get rodents in the car. I've been looking at those gaping mouse portals and wondering how to deal with them myself. You can’t seal most cars against mice. They can get through a 1/4-1/2” opening. Yes, but that opening is particularly inviting. I'm a wildlife biologist and the shape and size of that area would make a darn good design for a nest box or shelter designed to attract many small mammals. I actually had a weasel living in that area of my car before I pulled my car out of hibernation. I like weasels, but less so in the car. I totally agree with the futility of making a car rodent "proof", but rodent "resistant" is doable. Is there anything to put in or under the car that keeps them away, other than a cat. |
ndfrigi |
Jun 11 2019, 03:30 PM
I try to keep the neighbor’s cat away from my garage because it goes In through our patio to garage. Maybe I will feed that cat so it will visit my garage regularly. Problem that cat sleeps on top of my boxster convertible and leaves some stains. huhuhu
bbrock |
Jun 11 2019, 05:35 PM
Thanks Gents - no cover for the hole and a gap around the steering column boot to the bulkhead it is. It just kinda surprises me thats the original solution cuz that steering rack cover doesn't really seal up the area from below. Definitely enough to keep the water and debris out, but not really dust and critters. Anyway, mystery solve for me. Thanks! Well dangit, I was hoping you'd come up with a clever solution because I agree with you this is a problem. Where I live, leaving a car outside just 30 minutes after dark is guaranteed to get rodents in the car. I've been looking at those gaping mouse portals and wondering how to deal with them myself. You can’t seal most cars against mice. They can get through a 1/4-1/2” opening. Yes, but that opening is particularly inviting. I'm a wildlife biologist and the shape and size of that area would make a darn good design for a nest box or shelter designed to attract many small mammals. I actually had a weasel living in that area of my car before I pulled my car out of hibernation. I like weasels, but less so in the car. I totally agree with the futility of making a car rodent "proof", but rodent "resistant" is doable. Is there anything to put in or under the car that keeps them away, other than a cat. There are a few rodent repellents that can work but they don't last very long. I was using a product called Fresh Cab in my work truck that is always parked outside with good results for awhile. The stuff only remains effective for a month or two though and isn't cheap so I gave up and now my truck smells like mouse pee again. That was really asking too much from a repellent though. For a car stored inside, it would probably provide enough deterrent to keep the occasional mouse away. Steel wool is excellent for plugging holes because rodents won't chew it, but of course, not good for nice cars where you'd rather prohibit rust than promote it. The two problems with cats are that they like to jump up on cars and they kill 1-4 billion birds in the U.S. every year so not an environmentally friendly form of pest control if allowed to run free. They're great inside garages and barns though. Beyond a well-sealed building to store our cars in, I think just keeping seals in good shape and rust holes plugged so the mice at least have to work to get in the car is the most practical bet. Overall, I think our 914s are an excellent design from a rodent resistance standpoint. The only real problem spot I've seen is that stinkin' hole under the fuel tank. That's just a welcome mat for mice to set up shop in a spot that is a real PITA to clean out. |
Lo-Fi Version | Time is now: 26th April 2024 - 03:05 AM |
