Cover for hole under Gas Tank and Seal around Steering column?, Wondering what fills the hole and gap |
sketchc13 |
Jun 5 2019, 10:12 AM
Newbie Group: Members Posts: 13 Joined: 7-February 11 From: NorCal Member No.: 12,675 Region Association: Northern California |
I have my gas tank out and under it there is a ~100mm hole on the passenger side and a gap around the boot where the steering column goes through the body on the way to the steering rack.
Is something missing? Coming from Wisconsin, the hole and gap are very inviting to garage invading squirrels to store their nuts and more in the fall and winter and it seems like something should go there.... Are there OE parts that go there or did any one fab something up for the hole and gap? See attached pic... I have since cleaned up the surface rust. Cheers, Andrew |
Literati914 |
Jun 23 2019, 10:41 AM
Senior Member Group: Members Posts: 1,464 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
So, if not running a splash shield, isn't this hole also an access point for water and rust (tho I can not remember this being a common rusty area, now that I think of it..) ?
bbrock |
Jun 24 2019, 10:30 AM
So, if not running a splash shield, isn't this hole also an access point for water and rust (tho I can not remember this being a common rusty area, now that I think of it..) ? I had to patch quite a few rust holes in that area even with the gravel shield always being on the car. I would worry about my steering rack bellows getting torn up running without the shield, but I agree that hole would be a good mud collector too. |
Lo-Fi Version | Time is now: 24th May 2024 - 05:07 AM |
