Reassembly started...Malaga'76 V8, Help needed with doors/glass |
DickSteinkamp |
Jun 7 2019, 02:58 PM
Senior Member Group: Members Posts: 500 Joined: 27-February 17 From: Bellingham, WA Member No.: 20,876 Region Association: None |
I've started the reassembly of my project '76 V8. 2 years in the making to this point (IMG:style_emoticons/default/cheer.gif) . I've had it together and apart and together and apart so many times before paint that it is going pretty quickly. Everything fits and I usually remember how to do it...
(IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-20876-1559941089.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-20876-1559941090.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-20876-1559941090.3.jpg) ...except for the doors. I wanted the glass and rubber out for paint, so I don't have the same experience reassembling as I do on the rest of the car. It looks like a 3D puzzle (IMG:style_emoticons/default/confused24.gif) Any hints on assembly sequence and tips for the parts that are most difficult would be appreciated. |
rhodyguy |
Jun 7 2019, 03:48 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,072 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
New outer fuzzy strips pre windows. Post. New f&r window channel. You going with all new seals and whatnot? The Malaga looks great with the chrome bumpers. Was it panted local to Bham?
Cairo94507 |
Jun 7 2019, 04:07 PM
Michael Group: Members Posts: 9,725 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Your car looks stunning. (IMG:style_emoticons/default/smilie_pokal.gif)
DickSteinkamp |
Jun 7 2019, 05:26 PM
New outer fuzzy strips pre windows. Post. New f&r window channel. You going with all new seals and whatnot? The Malaga looks great with the chrome bumpers. Was it panted local to Bham? Thanks. I get what you mean by F & R window channel, but not what you mean by "outer fuzzy strips pre windows" and "post". (I'm a rookie with these cars. My first). For the doors, have new outer rubber scrapers and side targa top seals. I think I talked myself into triangle window seals. Mine are "OK", but probably not good enough. I have replaced some rubber on the rest of the car, but much of it was just fine. You stock 76 lovers will shoot me, but I started with a rust free (I mean COMPLETELY rust free), no hit, low mile, SoCal car in original paint. It must have been garaged its whole life. Original owner. He had torn it down several years ago for a repaint and then did nothing other than loose the engine (IMG:style_emoticons/default/sad.gif) . I bought it in baskets. Just what I wanted for my project, however. I did the prep for paint and a buddy here in Bellingham who is much better than me with a paint gun sprayed it. |
DickSteinkamp |
Jun 7 2019, 05:41 PM
Thank you! My vision was a relatively stock looking early 914 but with a little more go. The engine is just a 305, but it's a Firebird/Camaro LB9 which made about 220 HP stock. The TPI wouldn't fit, so a 4 BBL now. It does have a Thumper cam, so maybe a shade more than 220 HP. Plenty for me! Mostly Renegade/KEP parts for the conversion. |
rhodyguy |
Jun 8 2019, 09:07 AM
2 complete door packages reasonably priced at 914rubber. The outer fuzzy strips are below the side window squeegees. You can't access the screws with the windows installed.
DickSteinkamp |
Jun 8 2019, 09:59 AM
1970-1914 |
Jun 8 2019, 04:13 PM
Member Group: Members Posts: 97 Joined: 3-June 18 From: Vancouver Member No.: 22,186 Region Association: Canada |
Looking great!
Pierre |
barefoot |
Jun 9 2019, 07:24 AM
Senior Member Group: Members Posts: 1,271 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
2 complete door packages reasonably priced at 914rubber. The outer fuzzy strips are below the side window squeegees. You can't access the screws with the windows installed. Those 3 tiny screws where the ONLY fasteners on the whole car i could not break loose, so I did not install new outer door fuzzies. Good luck ! |
DickSteinkamp |
Jun 15 2019, 09:12 AM
I found this old post from Mikey...
Triangle Window Seal Thanks for doing this Mikey. It should be in the Tech Articles. Well done! |
horizontally-opposed |
Jun 15 2019, 11:03 AM
Advanced Member Group: Members Posts: 3,431 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None |
Wow, does your car look good[u]. I am partial to rich reds, and this one is a stunner. (IMG:style_emoticons/default/wub.gif)
Another good link that I found helpful for the side windows—so helpful it's bookmarked. http://www.914world.com/bbs2/index.php?sho...p;#entry2000174 The triangle windows and A pillars are one of the most hasslesome things on the whole car to get right...and mine still aren't right. Part of the problem is the new rubber from Porsche Classic is too hard. Been thinking about changing to Mikey's to see if that helps. In any event, be patient and take your time. |
DickSteinkamp |
Jun 15 2019, 02:44 PM
Thanks, HO!
whitetwinturbo |
Jun 21 2019, 08:11 PM
Honey, does this wing make my ass look fat? Group: Members Posts: 1,391 Joined: 22-October 11 From: Newport Beach/Kalefornya/USA Member No.: 13,704 Region Association: Southern California |
(IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/wub.gif) (IMG:style_emoticons/default/popcorn[1].gif) .............which red is that beauty?
76-914 |
Jun 21 2019, 08:26 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
2 complete door packages reasonably priced at 914rubber. The outer fuzzy strips are below the side window squeegees. You can't access the screws with the windows installed. Those 3 tiny screws where the ONLY fasteners on the whole car i could not break loose, so I did not install new outer door fuzzies. Good luck ! FWIW, I ran into that on my '73. IIRC, after I removed the window I was able to drill out those screws with a #40 6" drill bit. Sometimes called an aviation bit. (IMG:style_emoticons/default/beerchug.gif) Highjack over. BTW, nice car. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 4th May 2024 - 01:20 PM |
