6.5x15 Steel'ies, Steel Wheels |
brainf18 |
Jun 8 2019, 04:26 PM
Newbie Group: Members Posts: 19 Joined: 12-May 19 From: Louisville KY Member No.: 23,116 Region Association: None |
I was looking for a set of 6.5x15 steel wheels for track days. I wanted to run 205/15's all the way around. Wasn't able to find any low cost "off the shelf" solutions for an unmodified 4x130 bold pattern. So I settled on 5.5in wheels and ordered a set from Sierra Madre Classics. ($59 each)
When the wheels arrived, they looks suspiciously larger than 5.5 inchs. So I put a tape measure on them and to my surprise they were just a few mils under 6.5 inches wide. I test mounted this morning and the backspacing and offset were spot on. Problem solved. Though others might like to know... https://sierramadrecollection.com/Steel-Whe...1-2-p19583.html [/url] |
michael7810 |
Jun 8 2019, 04:49 PM
Senior Member Group: Members Posts: 1,081 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region |
I don’t know how to measure wheels but those are 5-1/2 measured on the inside of the bead edge
porschetub |
Jun 8 2019, 04:58 PM
Advanced Member Group: Members Posts: 4,701 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
(IMG:style_emoticons/default/agree.gif) its done on the inside where the tyre mounts...wish they made a 6.5'' size they would sell like hot cakes IMO.
mark04usa |
Jun 8 2019, 05:35 PM
'70 1.7 Tangerine Group: Members Posts: 351 Joined: 14-September 09 From: Austin TX Member No.: 10,805 Region Association: Southwest Region |
Sure is a fine looking steely, though. Haven't seen any 6.5" steelies.
brainf18 |
Jun 8 2019, 05:49 PM
(IMG:style_emoticons/default/agree.gif) its done on the inside where the tyre mounts...wish they made a 6.5'' size they would sell like hot cakes IMO. If that's the case then its still a 6 in wheel....Can still run a 205 tire. |
DickSteinkamp |
Jun 8 2019, 05:52 PM
Senior Member Group: Members Posts: 500 Joined: 27-February 17 From: Bellingham, WA Member No.: 20,876 Region Association: None |
Wheels are measured inside to inside of the bead. You have 5 1/2" wheels.
mepstein |
Jun 8 2019, 06:01 PM
914-6 GT in waiting Group: Members Posts: 19,279 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
brainf18 |
Jun 8 2019, 06:46 PM
michael7810 |
Jun 8 2019, 07:08 PM
I run 205s on my 2L Fuchs and they are 5.5s. 30K miles with no problems
porschetub |
Jun 8 2019, 07:51 PM
(IMG:style_emoticons/default/agree.gif) its done on the inside where the tyre mounts...wish they made a 6.5'' size they would sell like hot cakes IMO. Yep said that (IMG:style_emoticons/default/dry.gif) ,don't know anyone making a wheel this width ,you will be fine with 205's as so many doing the same,keep the profile correct and that saves a incorrect speedo reading also. |
chrisg |
Jun 8 2019, 08:01 PM
Member Group: Members Posts: 63 Joined: 20-December 03 From: Paso Robles, CA Member No.: 1,455 Region Association: None |
What do they weigh? I assume all steelies of similar size are in the 18.5 lb. range, but just for curiosity sake, can you let us know?
brainf18 |
Jun 8 2019, 09:08 PM
80’s old school |
Jun 23 2019, 07:19 PM
Member Group: Members Posts: 79 Joined: 26-March 19 From: California Member No.: 22,994 Region Association: Southern California |
Have you mounted these up yet? I want to see what these Steelies look like on the car with 195 or 205 tires.
Mark Henry |
Jun 23 2019, 08:17 PM
You could make your own in 15x7"
Grind the welds out of a set of old wheels for the centers, buy a set of barrels and weld them in. A hub and a lathe with a big enough swing would make the lay-up job easy. I did the 24" front wheels on my tractor with just a straightedge and a caliper and it runs straight, mounting/measuring on a lathe will be very accurate. When I bought my barrels 15x7" were available. |
sixnotfour |
Jun 24 2019, 03:28 PM
914 Wizard Group: Members Posts: 10,433 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Wheel, OEM VW, Steel, Silver, 15 in. x 6 in., 4 x 130mm Bolt Circle, 5 in. Backspace, Each $62
https://www.summitracing.com/parts/usw-131-5630/overview/ |
IronHillRestorations |
Jun 24 2019, 06:56 PM
I. I. R. C. Group: Members Posts: 6,719 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Wheel, OEM VW, Steel, Silver, 15 in. x 6 in., 4 x 130mm Bolt Circle, 5 in. Backspace, Each $62 https://www.summitracing.com/parts/usw-131-5630/overview/ I thought 4.75" was the most backspacing you can get on the rear of a 914 |
Jun 24 2019, 07:08 PM
I was wrong. 7" 911R wheels will go on the back of a 914 and the backspacing for those is 138mm which is 5.43"
80’s old school |
Jun 24 2019, 10:10 PM
Wheel, OEM VW, Steel, Silver, 15 in. x 6 in., 4 x 130mm Bolt Circle, 5 in. Backspace, Each $62 https://www.summitracing.com/parts/usw-131-5630/overview/ Cool. If this size is for real. This will be the ticket for me. Thanks. I will check into this further. I noticed my local Americas Tire carries this. |
Lo-Fi Version | Time is now: 22nd May 2024 - 10:58 AM |
