Are Koni shocks still hard to come by? |
Jun 9 2019, 10:37 PM
It looks like i blew out two of my Koni adjustable shocks this weekend on those fine SoCal freeways. Both the drivers side front and rear are leaking a lot of oil out the top.
(IMG:style_emoticons/default/dry.gif) Anyways, i remember that some years ago they were hard to come by and all the major outlets had them listed but actually didn't have any in stock. Anyone had any luck lately in buying a full set somewhere? (IMG:style_emoticons/default/idea.gif) |
914_7T3 |
Jun 9 2019, 10:49 PM
Please forgive me, I'm new to all of this! Group: Members Posts: 1,853 Joined: 3-April 17 From: Los Angeles, CA Member No.: 20,991 Region Association: Southern California |
It looks like i blew out two of my Koni adjustable shocks this weekend on those fine SoCal freeways. Both the drivers side front and rear are leaking a lot of oil out the top. (IMG:style_emoticons/default/dry.gif) Anyways, i remember that some years ago they were hard to come by and all the major outlets had them listed but actually didn't have any in stock. Anyone had any luck lately in buying a full set somewhere? (IMG:style_emoticons/default/idea.gif) @SirAndy Picked up a set of fronts last June from Pelican and they were in stock so you can try there. |
Krieger |
Jun 9 2019, 11:12 PM
Advanced Member Group: Members Posts: 4,711 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
I think it was the Red shocks that were hard to come by. They may have stopped making them a few years back. The Yellow Sports were still available last I checked. PSI at Sears Point can rebuild your old ones, but it's not cheap.
914_7T3 |
Jun 9 2019, 11:15 PM
I think it was the Red shocks that were hard to come by. They may have stopped making them a few years back. The Yellow Sports were still available last I checked. PSI at Sears Point can rebuild your old ones, but it's not cheap. Yes, the fronts are yellow, but used a rebuilt set of reds in the rear. |
koozy |
Jun 10 2019, 03:21 AM
Senior Member Group: Members Posts: 651 Joined: 21-July 07 Member No.: 7,931 Region Association: None |
Andy, Tire Rack has them. Link below gets you to both fronts and rears in a Tire Rack search
https://tinyurl.com/yyosqo6s |
914Sixer |
Jun 10 2019, 06:20 AM
Red rears are NLA. Porsche does have the adjustable rears in black BUT they are NOT external adjustment. Koni front reds are available as Koni Classic but they are NOT external adjustment either. All Koni yellows are GAS shocks.
I have a set of NOS Front Koni's but they have to be adjusted before installation. |
roblav1 |
Jun 10 2019, 07:05 AM
Senior Member Group: Members Posts: 528 Joined: 18-September 12 From: KY Member No.: 14,943 Region Association: MidAtlantic Region |
You can get those rebuilt somewhere. Shock oil and seals is about it. Years ago, TruChoice used to do them.
jcd914 |
Jun 10 2019, 08:38 AM
Koni's used to carry a lifetime warranty to the original purchaser.
They had to be sent to a specific place (maybe Truchoice) and you had to have your receipt to show you were the original purchaser. I had a set that lost gas pressure and they replaced them. No idea if that is still their policy. Jim |
Andyrew |
Jun 10 2019, 09:32 AM
I bought some yellows on ebay. they were pretty cheap and fit right in my struts.
Those roads are crap crap crap..... https://www.ebay.com/itm/Koni-8641-1039SPOR...872.m2749.l2649 |
bdstone914 |
Jun 10 2019, 10:03 AM
@SirAndy
I have used Koni rear red rear you can have for shipping cost. Maybe a pair of inserts They are old style oil filled. Might have a usable pair. Or use these to get rebuilt and then swap them out. Koni availability is hit and miss on new inserts and shocks. Used to have to call them when I worked at Pelican to verify actual availability. You are better off with new shocks all around. Bruce |
Jun 10 2019, 10:25 AM
Red rears are NLA. Porsche does have the adjustable rears in black BUT they are NOT external adjustment. Koni front reds are available as Koni Classic but they are NOT external adjustment either. All Koni yellows are GAS shocks. I have a set of NOS Front Koni's but they have to be adjusted before installation. They are the yellow ones that have the external adjuster on top and i too thought they were GAS shocks but both of them are leaking OIL from the top. So now i'm more confused than usual ... (IMG:style_emoticons/default/unsure.gif) |
jkb944t |
Jun 10 2019, 11:09 AM
Member Group: Members Posts: 464 Joined: 17-January 05 From: Canton, OH Member No.: 3,459 Region Association: None |
Red rears are NLA. Porsche does have the adjustable rears in black BUT they are NOT external adjustment. Koni front reds are available as Koni Classic but they are NOT external adjustment either. All Koni yellows are GAS shocks. I have a set of NOS Front Koni's but they have to be adjusted before installation. They are the yellow ones that have the external adjuster on top and i too thought they were GAS shocks but both of them are leaking OIL from the top. So now i'm more confused than usual ... (IMG:style_emoticons/default/unsure.gif) Gas shocks do have oil in them. A gas charged shock or strut uses high-pressure nitrogen gas to reduce oil foaming during high-speed damping, and therefore maintains performance. Jeff B |
horizontally-opposed |
Jun 10 2019, 01:21 PM
Advanced Member Group: Members Posts: 3,432 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None |
Koni front reds are available as Koni Classic but they are NOT external adjustment either. Took a look at their site, but unable to find them there. Ideas for other sources online? Would like to get a look at these, as I am considering having a pair of rear reds rebuilt but need red fronts. If the new ones include spindles… (IMG:style_emoticons/default/idea.gif) Everyone tells me the Bilstein HDs I installed are the superior shock absorber, but my butt dyno suggests Koni reds are very hard to beat on the street short of the exotic stuff like JRZ, etc, which can be wonderful once you figure out how to dial them in. Sometimes, KISS really is the way to go. |
914Sixer |
Jun 10 2019, 01:27 PM
Just posted some Koni Reds for sale in classified.
michael7810 |
Jun 10 2019, 01:28 PM
Senior Member Group: Members Posts: 1,081 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region |
PSI rebuilt my 944 Koni yellows a couple years ago. Can’t remember the cost but it wasn’t bad.
Jun 10 2019, 01:57 PM
PSI at Sears Point can rebuild your old ones, but it's not cheap. I'll get in touch with them and see how much they want. They're just up the road from me ... (IMG:style_emoticons/default/smile.gif) |
sixnotfour |
Jun 10 2019, 02:00 PM
914 Wizard Group: Members Posts: 10,432 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
good ole Paragon Products
https://www.paragon-products.com/Porsche-91...truts-s/284.htm |
Jun 10 2019, 02:52 PM
I know who *lists* them, that's not the problem. I'd like to know who actually has them in stock, hence my original question asking if anyone had any luck actually getting any lately. (IMG:style_emoticons/default/shades.gif) |
eeyore |
Jun 10 2019, 03:06 PM
How could you expect the OP to do something as difficult as pick a phone and call vendors? |
johnlush |
Jun 10 2019, 03:11 PM
What's all this then? Group: Members Posts: 371 Joined: 26-May 04 From: Cheyenne, WY Member No.: 2,108 Region Association: Rocky Mountains |
Last ones I got were from Paragon. The owner (as far as I know he still is) is Jason Burkett who is a fellow enthusiast and a great source of information. Might be worth pinging him...
Lo-Fi Version | Time is now: 17th May 2024 - 02:38 PM |
