Washer Stalk Question .. |
Literati914 |
Jun 11 2019, 10:51 AM
Senior Member Group: Members Posts: 1,443 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
I'm gonna order the following items to convert over to an electric windshield washer system, but have some questions about the washer stalk on the column. With the stock set up, how many speeds are there for the wiper action? Is it JUST low and hi only, or is there a middle speed too? (too many years since my last 914 to remember, and it hardly ever rains, so..) Also, is there an intermittent action (I doubt), and is there a way to add it? Same question with the replacement stalk I'm considering (see link)?
https://www2.cip1.com/ProductDetails.asp?Pr...C-111-953-519-G and https://www.ebay.com/itm/BRAND-NEW-WINDSHIE...scAAOSw5ZBWPTnf . |
SirAndy |
Jun 11 2019, 11:28 AM
Resident German Group: Admin Posts: 41,612 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Also, is there an intermittent action (I doubt), and is there a way to add it? Yes, there was an optional intermittent relay and wiring harness for later cars. It simply mounts in-line with the current wiring, no cutting needed. Do a search here for "intermittent", there are several threads about it. I show the location of the relay (socket) in this tech article: http://www.914world.com/specs/tech_el_washer.php (IMG:style_emoticons/default/bye1.gif) |
Literati914 |
Jun 11 2019, 12:35 PM
.. Yes, there was an optional intermittent relay and wiring harness for later cars. It simply mounts in-line with the current wiring, no cutting needed. .. Thanks Andy. So, when adding this relay, how does your interaction with the stalk change? Up for intermittent, down..? Ok, you did suggest searching intermittent - the answers are probably there - I'll look again. Good write-up, BTW. Thanks. |
SirAndy |
Jun 11 2019, 12:48 PM
So, when adding this relay, how does your interaction with the stalk change? Up for intermittent, down..? Later columns have the internals for the intermittent already built in. All you have to do (after installing the extra harness and relay) is to break off a small plastic tab to allow the stalk to go down one more position to engage the intermittent circuit. (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 3rd May 2024 - 04:12 PM |
