Clutch adjustment issues !, needs to be adjusted again..something wrong ? |
porschetub |
Jun 11 2019, 07:28 PM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Got the car out of storage for a startup and short drive yesterday,noticed the engagement point is high on the pedal (again),obviously isn't happy there,and not fun to drive this way.
Sometime back I shimmed the ball pivot as it was clear the throw out lever was contacting the gearbox casing...not by much but after measurement it appeared my flywheel had been resurfaced @ some stage but still in spec. Cable was new when I did the 6 conversion 708kms ago,and I cant find any movement in the tunnel tube,clutch is new and all wear parts replaced on the throw-out lever and bearing,have new 914rubber cable roller also. Really got me buggered this one ,why do I need to adjust it so often.....bad cable who knows. TIA |
Spoke |
Jun 11 2019, 07:35 PM
Jerry Group: Members Posts: 6,976 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
I went through about a month of clutch adjustments before the cable snapped.
Lo-Fi Version | Time is now: 26th April 2024 - 06:07 AM |
