Fuching DJet issues *SOLVED*, Running out of things to try |
rjames |
Jun 12 2019, 12:19 AM
I'm made of metal Group: Members Posts: 3,914 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Last summer all of a sudden my car wouldn’t stay running. If I could get it started the idle would hunt and the car would die unless I kept on the gas. Lack of power at times. All somewhat erratic.
Found that the MPS wouldn’t hold vacuum. Replaced the bad mps with a known good one. Car idles high when cold (higher than I think it should ~1600 rpm) so AAR is good, then when it warms up idle hunts from ~900rpm to the point where it almost dies unless I open the throttle body bleed screw quite a bit and turn the ECU knob just a few clicks away from full clockwise. So I did the following hoping to fix the issue: Replaced all vac hoses including intake runner to plenum hoses. New intakecrunner gaskets Verified plenum isn’t leaking New throttle body gasket Installed NOS throttle body Rebuilt the distributor New condenser Rebuilt injectors and flow tested New fuel lines Fuel pump is less than 2 years old Set timing and dwell with advance disconnected New CHT (resistance reads 1.7 w/engine off @70 degrees in the garage) Calibrated the TPS, even unplugged it to take it out of the equation, didn’t change anything. ECU matches the MPS (both correct part #s for a ‘75 2.0) Tried a known good ECU from a ‘74, no change. Feels like the MPS needs to be calibrated...but then again, these are all the same symptoms I had with the old bad mps. Replacement mps is from a Jeff B and was tested, but I haven’t retested it to see if it’s holding vacuum. (Don’t have the necessary tool, but maybe that’s the next step) Help! What am I missing? |
rjames |
Jun 13 2019, 01:47 PM
Ok, more testing = more results.
Distributor canister won’t hold a vacuum. Only the retard side is hooked up, and that will effect idle, (if I understand how it works correctly), but if I disconnect the retard hose and plug it at Bothell the TB and the dizzy, issue is still there. So after finding that issue... With all hoses disconnected and capped my AFR tells me that ratio goes from 14 to full lean in synch with the fluctuating idle. I don’t have a tool to measure fuel pressure (yet) but I did stick my ear down by the fuel pump and it gets louder/quieter as the idle surges up and down. Hmmm... May have just identified the main culprit. Hopefully it’s just a clogged fuel filter, or it could be a bad pump (even though it’s a new Bosch unit(which would $uck). I cleaned the tank and installed new sock a few years ago so that should be ok. Can I run the pump without fuel for any length of time without damaging it to test it? So... Where can I get a good distributor canister? Are they rebuildable? |
Lo-Fi Version | Time is now: 25th April 2024 - 11:22 PM |
