Straighten a bent trailing arm?, Can't align to within spec, Driver's rear measures bent |
rnellums |
Jun 14 2019, 10:23 AM
Professional Enthusiast Group: Members Posts: 1,646 Joined: 26-November 09 From: Littleton, CO Member No.: 11,072 Region Association: Rocky Mountains |
Hey all,
I've got some issues aligning my flared 914. With the drivers rear at the limit of travel I'm still quite a bit toe out. Measurements of the hub-pivot distance are a bit longer on the drivers vs. the passenger rear. the bend isn't visually noticeable, but its there. Has anyone had luck trueing it up or should I just find another trailing arm and move on? Thanks! -Ross |
jkb944t |
Jun 14 2019, 10:28 AM
Member Group: Members Posts: 464 Joined: 17-January 05 From: Canton, OH Member No.: 3,459 Region Association: None |
Hey all, I've got some issues aligning my flared 914. With the drivers rear at the limit of travel I'm still quite a bit toe out. Measurements of the hub-pivot distance are a bit longer on the drivers vs. the passenger rear. the bend isn't visually noticeable, but its there. Has anyone had luck trueing it up or should I just find another trailing arm and move on? Thanks! -Ross I would think it would be easier, cheaper and faster to just get another used control arm if it is in fact bent. I would also check the inner control arm mount to make sure it is in the right location and is not cracked. Jeff B |
Lo-Fi Version | Time is now: 22nd May 2024 - 04:51 AM |
