Straighten a bent trailing arm?, Can't align to within spec, Driver's rear measures bent |
rnellums |
Jun 14 2019, 10:23 AM
Professional Enthusiast Group: Members Posts: 1,646 Joined: 26-November 09 From: Littleton, CO Member No.: 11,072 Region Association: Rocky Mountains |
Hey all,
I've got some issues aligning my flared 914. With the drivers rear at the limit of travel I'm still quite a bit toe out. Measurements of the hub-pivot distance are a bit longer on the drivers vs. the passenger rear. the bend isn't visually noticeable, but its there. Has anyone had luck trueing it up or should I just find another trailing arm and move on? Thanks! -Ross |
rnellums |
Jun 14 2019, 10:34 AM
Hey all, I've got some issues aligning my flared 914. With the drivers rear at the limit of travel I'm still quite a bit toe out. Measurements of the hub-pivot distance are a bit longer on the drivers vs. the passenger rear. the bend isn't visually noticeable, but its there. Has anyone had luck trueing it up or should I just find another trailing arm and move on? Thanks! -Ross I would think it would be easier, cheaper and faster to just get another used control arm if it is in fact bent. I would also check the inner control arm mount to make sure it is in the right location and is not cracked. Jeff B Easier - maybe, but ill have to swap over the hub, my polybronze bushings, and the bearings (if I can save them) Cheaper - maybe, but I'd have the cost of a new arm and shipping, likely a new rear bearing, potentially new polybronze bushings. it definitely adds up. Faster - agreed. I just had the suspension off and the inner mounts are good (and have additional bracing welded on). always a good idea to check though! I think TangeringeRacing (RacerChris) can help you out with that. Or roll the dice on a used one and hope it's not bent either. That was kind of my thinking. there is a decent chance I buy and arm and it arrives bent too. Probably ought to give Chris a call. |
jd74914 |
Jun 14 2019, 12:22 PM
Its alive Group: Members Posts: 4,780 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
I think TangeringeRacing (RacerChris) can help you out with that. Or roll the dice on a used one and hope it's not bent either. That was kind of my thinking. there is a decent chance I buy and arm and it arrives bent too. Probably ought to give Chris a call. (IMG:style_emoticons/default/agree.gif) Chris can likely sell you a known straight arm at the least since he has jigging to check. |
ChrisFoley |
Jun 16 2019, 07:37 AM
I am Tangerine Racing Group: Members Posts: 7,928 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I think TangeringeRacing (RacerChris) can help you out with that. Or roll the dice on a used one and hope it's not bent either. That was kind of my thinking. there is a decent chance I buy and arm and it arrives bent too. Probably ought to give Chris a call. (IMG:style_emoticons/default/agree.gif) Chris can likely sell you a known straight arm at the least since he has jigging to check. I don't have any spares. They aren't hard to measure as long as you have a way to secure a pivot shaft elevated 6" above a work surface and perfectly level. |
guywan914 |
Jun 16 2019, 10:29 AM
Member Group: Members Posts: 221 Joined: 27-May 04 From: Columbia,CT Member No.: 2,112 |
I think TangeringeRacing (RacerChris) can help you out with that. Or roll the dice on a used one and hope it's not bent either. That was kind of my thinking. there is a decent chance I buy and arm and it arrives bent too. Probably ought to give Chris a call. (IMG:style_emoticons/default/agree.gif) Chris can likely sell you a known straight arm at the least since he has jigging to check. I don't have any spares. They aren't hard to measure as long as you have a way to secure a pivot shaft elevated 6" above a work surface and perfectly level. I have three that I could drop off to Chris if you wanted to have him check them. Which side do you need? |
Lo-Fi Version | Time is now: 22nd May 2024 - 01:14 PM |
