Brake light switch puzzle., Why is this happening, what am i missing? |
drem914 |
Jun 14 2019, 05:37 PM
Senior Member Group: Members Posts: 1,030 Joined: 16-May 08 From: Trabuco Canyon, CA Member No.: 9,062 Region Association: Southern California |
I had my brake lights go out on me at WCR. A couple of members offered to help replace or the switch and now I am thinking I should have taken them up on the offer.
The problem is when I install the new switch it does not work. The switch is good mind you. I have tested it outside of the car and it switch current off and on. Wwhen I plug in the electrical connection with out mounting on pedal bracket, the switch works. It closes the circuit defaulting to ON when left free. Now when I go to mount the same switch to the bracket, the switch no longer works. It is not about how much the arm moves. as soon as the switch base touches the bracket the switch motion is meaningless. it just won't close the circuit for bright brake lights. What is causing the short? Is there supposed to be a separator between the switch and the bracket? Any suggestions at this point? TIA |
lierofox |
Jun 15 2019, 11:19 PM
Member Group: Members Posts: 256 Joined: 23-June 15 From: Paso Robles, CA Member No.: 18,880 Region Association: Southern California |
There is no separator/insulator since the switch should be isolated by virtue of the fact that the screw threads on the switch are just inserts pressed into the plastic and shouldn't be connected to any other metal in the switch. (I've used both the URO and the Wittrin brand switches, and both of them are built roughly the same, and are both adjustable.)
In terms of adjustment, is the washer on the pedal able to FULLY pull away from the switch while it's being depressed, as in there's a gap between the switch arm, and the washer? If the washer is still touching the switch arm at all, the brake lights won't come on. The brake switch only makes contact and closes the circuit when it reaches the absolute end of stroke, which is set using the locknut/screw on the switch, I have mine adjusted so that the washer pulls away from the switch arm and actuates the lights just the tiniest bit before I start to feel any resistance from the brake pedal. With the switch mounted but no wires connected, are you able to get continuity between the terminals when you push the pedal? (And, if you're concerned about a short, with the wires disconnected and the switch mounted, are you able to get continuity between either terminal and the vehicle chassis ground?) If you have the wires connected (should be one with a bundle of ...I think 3 wires that provides power into the switch as well as teeing off to your reverse lights and another circuit, and another single wire that actually goes to your brake lights) do you see 12v on one side and ground on the other with the brake pedal at rest, and then do you see 12v on BOTH sides with the pedal pushed down? |
Lo-Fi Version | Time is now: 11th May 2024 - 11:57 PM |
