914-6 Fuel Line Size |
exsurfer |
Jun 15 2019, 08:10 AM
Newbie Group: Members Posts: 18 Joined: 2-June 19 From: La Canada Member No.: 23,187 Region Association: Southwest Region |
What are the factory fuel lines sizes on a 914-6, I can't find fuel section on PET 5
Had the orig. fuel pump serviced what to refresh the orig. lines. Thanks |
johnhora |
Jun 15 2019, 08:48 PM
Senior Member Group: Members Posts: 866 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None |
914-6 Fuel Pump
(S) Suction ....fuel tank to fuel pump OD 10mm (D) Discharge..fuel pump to carbs OD 8mm ® Return......fuel pump to fuel tank OD 8mm Original Plastic Lines... small line (return) 8mm....large line (suction) 10mm As mentioned the SS lines provided by tangerine are excellent. I used them to replace the aging plastic in my original 914-6...perfect fit. I purchased fuel hose here: https://www.belmetric.com/metric-hoses-c-14/ you can get OEM type fuel braided or smooth that are Multi-Fuel Hose-Ethanol Approved |
Lo-Fi Version | Time is now: 12th May 2024 - 11:06 AM |
